Old 06-29-2012, 06:45 AM   #21
chicken steve's Avatar
The Following 2 Users Say Thank You to chicken steve For This Useful Post:
chewy (08-06-2012), Going_Commando (09-09-2012)
Old 06-29-2012, 08:38 AM   #22
Bandwidth Conservator
Fredman's Avatar
Ran across this passage in an old wiring book tonight:
FISHING AND FISHING DEVICES
247a. Animals as Assistants:
The cat will usually walk toward and out of the illuminated end of the wireway bringing the pulling-in cord with her.
Or you would get to go find and clean out the dead strangled decomposing cat blocking your path.
Fredman is offline   Reply With Quote
Old 06-29-2012, 10:08 AM   #23
Chief Electron Relocator
Originally Posted by BBQ View Post
Hack data run.
Any work not performed by you is hack.
Old 06-29-2012, 10:20 AM   #24
BBQ
BBQ's Avatar
Hell no, lots of folks do better work than I.
But laying data cables on suspended ceilings is in my personal opinion hack work.
Please note I did not say I have never done it, I am just willing to admit I have short comings and at times do some hack work.
BBQ is online now   Reply With Quote
Old 06-29-2012, 10:36 AM   #25
erics37's Avatar
I once used a small R/C car to pull the jetline into a 6" pipe for the phone company's line into a hotel.
I also did some work in a huge warehouse where we needed to get some CAT5 cables across a drop ceiling. My helper showed up the next day with a crossbow. He had an arrow stuck into a rubber ball..... tie on the jetline to the arrow, load it up, and shoot it across the ceiling. Bingo.... within 10 seconds we're pulling across 150' of tile!
How did you strap those cables?
erics37 is online now   Reply With Quote
Old 06-29-2012, 10:41 AM   #26
...........But laying data cables on suspended ceilings is in my personal opinion hack work. ..........
Well, if you want to assume the cables were laying on the grid, so be it. Nothing I can do to convince you otherwise, despite that being the case.
Old 06-29-2012, 02:07 PM   #27
If the customer buys the velcro, I'll use velcro. Otherwise, it's electrical tape on a clean surface. Other than that, tie wraps. But only if my journeyman orders me to use them. I personally feel that a pinch every 10 feet isn't so great, but like you all say, shut up and listen to your journeyman.
kaboler is offline   Reply With Quote
Old 06-29-2012, 02:15 PM   #28
Data Tech/Apprentice.
chewy's Avatar
Its when the grid fails and people get trapped inside a building because of all the sh!t running on the grid that concerns me. AV and Fire Alarm guys over here are the worst. Not to mention the firefighters who could be in a building tearing grid down during a high rise fire, 1 cat5 in the wrong place could be life or death for them.
Old 06-29-2012, 02:20 PM   #29
chewy's Avatar
Really??? I hope you are just trolling because nobody could be this stupid not to mention completely oblivious to their own stupidity.
Old 06-29-2012, 08:41 PM   #30
Kaboler = Katroller.
The Following User Says Thank You to user4818 For This Useful Post:
chewy (06-30-2012)
Old 06-30-2012, 10:38 PM   #31
electrorick
RICK BOYD's Avatar
we had a remote army tank for a puller over dropped ceilings.
I know you understand
what you thought I said
but what you heard
is not what I meant
RICK BOYD is offline   Reply With Quote
Old 06-30-2012, 10:40 PM   #32
electrorick
RICK BOYD's Avatar
you tie the cat to the negative end , cat-ode ? cat-ion ?
247a. Animals as Assistants in Fishing.
In certain cases where other methods were not feasible, small animals have been used to draw pulling-in lines through wireways. Trained weasels have been used in threading underground conduit subways. In finished-building wiring, a cat can often be made to draw a cord through a raceway between floor and ceiling that is so obstructed by braces and bridges that it cannot be readily fished by the ordinary means. A length of cord is tied to a harness on the cat or to the animals tail. The cat is then placed in one end of the wireway and that end darkened. The far end of the wireway is illuminated with a candle if necessary. The cat will usually walk toward and out of the illuminated end of the wireway bringing the pulling-in cord with her.[/quote]
but what you heard
is not what I meant
Old 06-30-2012, 11:22 PM   #33
Ty Wrapp's Avatar
Don't cinch the tie wraps too tight, and place them at irregular intervals.
Ty Wrapp is offline   Reply With Quote
Old 06-30-2012, 11:24 PM   #34
chewy's Avatar
It thins out the electrons and gives multi pair conduction which results in higher rates of transmission if you cinch them down really tight, I recommend hiring a specialist with stranglers hands to do data looming.
The Following User Says Thank You to chewy For This Useful Post:
jeffmoss26 (07-30-2012)
Old 07-19-2012, 09:43 PM   #35
Can't Remember
Do they sell trained weasels at petco?
Old 07-19-2012, 09:48 PM   #36
erics37's Avatar
There are plenty of ferrets and other mustelids available for adoption from previous owners that abandoned or otherwise couldn't take care of them. Petco sells ferrets supplied by ferret mills. Next time you go there, look at the ferrets ears; if they have one or two small dots tattooed just inside their ear lobe, they were supplied by a ferret mill.
Here's a ferret rescue organization in New Hampshire:
http://www.ferretwise.org/
Old 07-28-2012, 11:42 AM   #37
Don't even get me started about low voltage installers, the only thing they seem to be good for is to use them for medical experiments, at this time am dealing w/the damage they did when installing their cable, in numerous locations the bozo's smashed holes through 2 hour firewalls & left it, not to mention the carnage left behind on the ductwork.
Norcal is online now   Reply With Quote
Old 07-28-2012, 12:06 PM   #38
We have a couple little ferret harnesses so we can take them for walks (which is an amusing affair, I assure you). But fitting a ferret with a harness and tying a lightweight pull string is the way to go. They wouldn't be able to pull heavier stuff very well.
we've been babysitting a ferret for several months while the owners are going thru a housing crunch. Love the little dude, he's affectionate, smart, REALLY quick learner, and will pull my 1/2" Milwaukee hammer drill across the floor by sinking his teeth into the resilient part of the handle grip. Agreed that would only use lightweight pull string tho. He loves pulling toys w/elastic string thru some 4" corrugated drain tubing we bought for him.
millelec is offline   Reply With Quote
The Following User Says Thank You to millelec For This Useful Post:
erics37 (07-29-2012)
Old 08-01-2012, 05:30 PM   #39
90Deg.bend's Avatar
I don't know about animals and electricity. I've seen what happens to a squirrel in a substation transformer. At least the blackened lump was the size of a squirrel.
90Deg.bend is offline   Reply With Quote
Old 08-05-2012, 11:07 PM   #40
goose134's Avatar
Well, now that we've got how to pull the conduits down, I guess we've got to figure out how to train a dog to sniff out boxes buried in the yard.
A professional in an amateur world.
Fishing doubleoh7 Off Topic 75 06-01-2012 09:57 AM
fishing green light Off Topic 13 03-13-2012 09:59 PM
Fly fishing blueheels2 Off Topic 24 04-27-2010 03:27 PM
Ice fishing with art BryanMD Off Topic 2 01-18-2010 09:28 AM
Fishing wire old house AKM General Electrical Discussion 23 10-26-2008 08:05 AM
