Old 11-01-2009, 09:16 PM   #1
Motor Repair&Control Shop
electro916's Avatar
Default Old volt-meter
I got this meter given to me by a friend of mine who is into old mining antiques. This is a DC voltmeter used in the mines, Im not really sure of the time period or what the 2-pin base is for above the gauge.
It has a 1 to 8 volt capacity, and it is a Weston Model 301, made by the Weston Electrical Instrument Corporation, Newark NJ
When somethings broke, I wanna put a bit of fixin on it
electro916 is offline   Reply With Quote
Old 11-05-2009, 07:02 PM   #2
With that voltage range I'm guessing that this was used to check primary cell voltages. I'm also guessing that the two-pin socket may have been used for a light bulb (looks like it's wired in parallel with the meter), say a 6V bulb, which may have been for meter illumination and/or a secondary visual indication of voltage level (plus it would load the cell as well).
sparky.jp is offline   Reply With Quote
Old 11-12-2009, 12:22 PM   #3
That range may be scaled to a much higher voltage. Not much use for a DCV meter that can only go to 8 volts. But I have never worked in a mine either.
It looks homemade too. Wooden mount? Maybe a panel mount meter?
Old 11-12-2009, 11:46 PM   #4
goose134's Avatar
I've got an old Weston meter as well. I looked it up on the interweb and found that Weston was the pretty much the guy who invented the ammeter. He's got about 300 patents to his name, and for a long time Weston meters were the standard. Here's a link if you'd like to read more about the company: http://weston.ftldesign.com/
New Volt Tic? 12-Gauge Tools, Equipment and New Products 95 12-12-2009 11:06 PM
320A meter, 200A meter, disc grouped? Marcopolo General Electrical Discussion 3 02-18-2009 10:26 PM
Elec meter 5' from a gas meter heel600 General Electrical Discussion 18 11-23-2008 04:43 PM
208 volt transformer on 240 volt? chadmiller Services and Service Equipment 3 05-06-2008 09:40 PM
DC Volt Meter brian john Vintage Electrical 3 06-16-2007 03:44 PM
