Old 03-11-2012, 08:42 AM   #1
Default 20a rccb
Is the any reason that I can't find 20A 4 pole RCCB to buy?. The minimum that I could find is 25A. Im doing spa room with sauna & jacuzzi. Sauna unit required 3 phases (6KW). As this is special location I need to RCD the all lot.
stozek is offline   Reply With Quote
Old 03-29-2012, 08:30 AM   #2
RCD must not be less, then automat.switch of the same line. 16A A.S.-so RCD should be from 16A and bigger. Regards.
Berlioz is offline   Reply With Quote
Old 04-25-2012, 04:47 PM   #3
Its better to be guided by the Manufacturers instructions on what they specify for their own kit. 20A for 6kW ?
A sparky friend of mine recently had a bit of an issue wiring a hot tub. It clearly stated in the manufacturer instructions that no RCD's were to be used due to the earth leakage of the tub. It wasn't british equipment.
WarrenG is offline   Reply With Quote
Old 04-27-2012, 09:42 AM   #4
Well, in the tub-12V, 0,6m from the tub (III zone)-a socket with RCD
Rccb , rcd , elcb , gfcp saba Residential Electrical Forum 28 01-08-2010 03:26 PM
Rccb trips intermittently wkyong General Electrical Discussion 1 07-09-2009 10:21 AM
