Old 10-17-2008, 02:48 AM   #1
bgec's Avatar
Send a message via MSN to bgec
Default Feeding switches
Hi guys, does anyone know of a regulation that provents you from feeding switches in a domestic lighting circuit. I can't think of one but i need a second opinion as someone questioned it and made me doubt myself.
Not that I am a sesItive guy or anything, thanks.
bgec is offline   Reply With Quote
Old 10-17-2008, 03:02 PM   #2
junior member UK
Default feedingswitches
No problem;
Iwas told by an NICIEC inspector that there is no problem with neutrals in switches you can use crimp, push fit or connector.
Do it all the time especially with wall lights and down lighters.
Feed the neutral through switch on a two way with 3 core and earth with live one end sw the other. Never had any problems
cornishsparks is offline   Reply With Quote
Old 10-17-2008, 04:31 PM   #3
52 gone, 53 arrived
Trimix-leccy's Avatar
Location: UK, by the seaside, besides the sea!! Home of the F1 Motor Racing WORLD Champion!! AGAIN!!!
Make sure you 'colour' the neutral ad DO NOT use the polythene type connector strip as it is not actually correct! I know every body does but it is wrong since it has a lower melting point than the PVC of the cable. USe nylon 6-6 or PVC type. Just trying out the 'push in connectors' at present; have not found any that you can 'disconnect' yet, so testing could be a problem
Trimix-leccy is offline   Reply With Quote
Old 10-17-2008, 05:16 PM   #4
can't see an issue as if you look at regs you have phase switching. secondly ip rated and grid switches tend to be double pole
sparkie is offline   Reply With Quote
Old 10-19-2008, 10:13 AM   #5
bgec's Avatar
Thanks for all your comments
my faith has been restored
12-2 feeding 12/3 subelect NEC Code Forum 4 11-09-2008 08:56 PM
Illuminated 3-way switches czars General Electrical Discussion 4 10-05-2008 09:59 AM
Question about back feeding Golden Arc General Electrical Discussion 44 07-29-2008 09:32 PM
Radio switches MDShunk General Electrical Discussion 5 09-05-2007 10:44 PM
