Have client from UK. How do they wire there? - Electrician Talk - Professional Electrical Contractors Forum
Old 05-09-2014, 06:00 PM   #1
Rewards Points: 588
Default Have client from UK. How do they wire there?
Can someone give me a rundown on how homes are wired in the UK? It seems to me that all recessed lights and fixtures are cut into the drywall on the finish. Most all of the high end electrical fixtures from UK manufacturers do not have a "rough in housing".
Pictures would be great.
JBrzoz00 is offline   Reply With Quote
Old 05-09-2014, 07:18 PM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
That's a good way to drive up the cost of the job.
Old 05-09-2014, 07:24 PM   #3
Rewards Points: 588
Yeah, I basically found the fixtures the lighting designer from the uk specd and found stuff that was made here. But even looking online it looks like all recessed is cut in after drywall, and the fixture boxes are all surface mounted.
Old 05-09-2014, 10:09 PM   #4
MTW
Megistered Rember
MTW's Avatar
Rewards Points: 6,287
For starters, it's nothing like North American wiring. They use 240 volts, ring circuits and fusible plugs, European color coding, their romex-style cable is much closer to UF cable, their load centers use IEC components and DIN rail (much like an industrial control panel), they don't use wire nuts, they use "trunking" (similar to our wire mold) and they talk with an English accent.
The Following User Says Thank You to MTW For This Useful Post:
chicken steve (01-04-2015)
Old 05-09-2014, 10:40 PM   #5
zac
Rewards Points: 788
Well if it's anything like their driving, I would watch out for reverse polarity!But seriously I thought the voltage was quite a bit higher.
Old 06-17-2014, 06:13 PM   #6
Are you still looking ?
great68 is offline   Reply With Quote
Old 06-17-2014, 10:16 PM   #7
FlyingSparks's Avatar
Rewards Points: 502
I was always fascinated by the ring circuits. 2.5mm wire (13awg-ish) on a 32a OCPD, that's a lot different haha
FlyingSparks is offline   Reply With Quote
Old 06-18-2014, 09:38 PM   #8
Fond of three phase
Rewards Points: 928
Ring circuits are supposed to start and finish at the same point. So, in reality the conductors are in parallel, throughout the entire run. That would double the ampacity of the circuit, unless the circuit is compromised by miss-wiring.
retiredsparktech is offline   Reply With Quote
Old 06-19-2014, 03:01 AM   #9
Yep. I have worked with these my whole life so are used to this configuration and the numerous faults due to a broken ring (quite common)
A concern nowadays is over here, in kitchens people are wanting a switch panel for all the appliances (for isolation for our regs) that has labeled switches in one place . This means the ring could be very unbalanced as say one leg has a 5m run to the board and the other 30m round the kitchen outlets also. Our 'normal' cable for this is 2.5mm which generally can carry 20A max.
The Following User Says Thank You to great68 For This Useful Post:
chicken steve (08-04-2015)
Old 07-12-2014, 12:49 PM   #10
Rewards Points: 29
Yeah, I basically found the fixtures the lighting designer from the uk specd and found stuff that was made here. But even looking online it looks like all recessed is drrtcut in after drywall, and the fixture boxes are all surface mounted.
Sent from my iPhone using electriciantalk.com
Enanosky44 is offline   Reply With Quote
Old 07-12-2014, 01:37 PM   #11
Rewards Points: 502
I see.
The Following User Says Thank You to FlyingSparks For This Useful Post:
icemanjc (07-12-2014)
Old 01-03-2015, 07:45 PM   #12
I am an electrician in the uk, what is it you want to know exactly
martinsparkylee is offline   Reply With Quote
Old 01-03-2015, 08:06 PM   #13
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 2,540
Welcome to ET,
Careful about zombie threads.
Old 01-03-2015, 08:16 PM   #14
Zombie threads? Sorry new to this
Old 01-03-2015, 08:24 PM   #15
Wirenuting's Avatar
That's ok, we all walk before we run.
Old 01-03-2015, 09:55 PM   #16
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
The thread is 7 months old and was no longer active. I'll bet the OP has not been here since then too, so he probably will not answer your post.
Welcome to the forum
CS2 Flat Rate
Old 01-03-2015, 10:31 PM   #17
Ah I see thanks I get what your saying
Old 01-04-2015, 06:04 AM   #18
Rewards Points: 35
I call it 'necro posting'
webelec is offline   Reply With Quote
Old 01-04-2015, 06:20 AM   #19
motherplucker
chicken steve's Avatar
Rewards Points: 5,696
I'm an electrician in America which is a rather isolated existence compared to the Euro electrical scene Martin.
Perhaps you blokes would be kind enough to take this opportunity to opine on your methods? For instance ring circuits>>
Why run a circuit this way would be my first Q.....?
chicken steve is online now   Reply With Quote
Old 01-04-2015, 11:27 AM   #20
Voltron's Avatar
Rewards Points: 304
Bloody good question old sport!
Voltron is offline   Reply With Quote
Tell a client about Zinsco? B W E General Electrical Discussion 81 12-10-2014 09:38 PM
When client refuses to pay Over Head? smileyfta Business, Marketing, and Sales 99 07-29-2013 07:48 AM
I love this type of client! BuzzKill Business, Marketing, and Sales 7 04-13-2012 06:01 AM
Value of a client list B W E Business, Marketing, and Sales 20 04-01-2012 08:05 PM
Awesome new client! B W E Off Topic (Non Trade) 10 03-07-2012 06:16 PM
