Old 10-02-2009, 04:00 PM   #1
Journeyman Wireman
crazymurph's Avatar
Default Hello to my Electrical brothers across the Atlantic
I read some of the posts in this section from time to time and need to know what are the terms you use compaired to our own. What I am saying is I do not completly understand UK wiring methods. What is a ring main? What is a spur cable? Could someone give me a brief explaination of the system. Thanks
crazymurph is online now   Reply With Quote
Old 10-02-2009, 05:15 PM   #2
52 gone, 53 arrived
Trimix-leccy's Avatar
Location: UK, by the seaside, besides the sea!! Home of the F1 Motor Racing WORLD Champion!! AGAIN!!!
Greetings.
We are on the whole very amicable, with the exception of a very few
Ring main...nearly always for a socket outlet circuit. Live neutral earth originate from fuse / mcb board taking the 'hot' [live] from the protective device, all cables loop in and out of every socket and 'hot' returns to the SAME protective device. Cct is fed from both ends and load is spread across the 2 legs.
Spur, usually a 'T' connection taken from a ring main . either from an existing socket or a joint box on the ring main. you cn have as many spurs as you have sockets. An unfused spur can only supply 1 socket [single or double]
does that explain it?
Trimix-leccy is offline   Reply With Quote
Old 10-02-2009, 05:38 PM   #3
Journeyman Wireman
crazymurph's Avatar
Thanks, Trimix. That helps some. Perhaps a link to a site that a DYI would use, something with photos and diagrams. Just trying to understand the methods used in the UK. After 30 years in the IBEW i am still learning how it is done in the states. It is tough keeping up on code changes and new products.
Old 10-02-2009, 07:04 PM   #4
52 gone, 53 arrived
http://en.wikipedia.org/wiki/File:Ring_circuit.svg
Greetings Brothers jdomain Introductions 5 09-29-2009 04:17 PM
Electrical connection question --Over-head electrical works SarahJennifer UK Electrical Forum 6 03-02-2009 11:32 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-29-2007 12:47 AM
