Old 10-15-2009, 03:57 AM   #1
Default Inspection & Testing
Good morning to you all! At the moment i am busy going through the remedial work after having the inspection and testing done on site at work. Now, I have done all Priority 1's and am going through the Priority 2's. I have come accross a Priority 2 that I cannot fix because i cannot get access to the cavity in the roof. The installation was put in when the building was constructed. the Fail or Priority 2 is that a shower room has a extractor fan on a switch fuse and the inspection says that it needs to be a pull switch as it is location in zone 2. So, As i cannot get access but still would like to comply as much as "reasonably practicable" What would you guys sugest I do. Hope to here from you wise ones soon. Thanks
Magic Electric is offline   Reply With Quote
Old 10-15-2009, 05:12 PM   #2
52 gone, 53 arrived
Trimix-leccy's Avatar
Location: UK, by the seaside, besides the sea!! Home of the F1 Motor Racing WORLD Champion!! AGAIN!!!
Pull switch and a fused spur? Ashley do a 3 pole pull switch version.
Just a thought, hard to say without seeing it
Trimix-leccy is offline   Reply With Quote
Old 10-16-2009, 03:45 AM   #3
I have got the 3 pole pull switch, however the switch fuse is on the wall of the shower room and i was going to replace it my wirring the pull switch but as i cannot get access to the cavity rewire is out of the question. Although the shower room is not uses very often so i would say that leaving it the way it is may be an option even though the switch is in zone 2. i wanted to see what all you wise ones thought about it. its making a small issue a really big and costly job.
Calling for inspection Hawk General Electrical Discussion 20 05-13-2009 09:36 PM
Inspection & Testing UK Gavin Adams UK Electrical Forum 18 10-20-2008 08:40 AM
inspection and testing neal green UK Electrical Forum 4 07-14-2008 05:39 PM
Inspection and testing in US. Fletchshef General Electrical Discussion 8 07-12-2008 07:03 AM
Inspection And Testing kevruta NEC Code Forum 6 12-19-2007 12:03 AM
