Old 06-25-2009, 07:41 AM   #1
Default Kva
Does anyone know how to work out amps from Kva,
is it volts/Kva/1.73*1000
Magic Electric is offline   Reply With Quote
Old 06-25-2009, 08:17 AM   #2
drsparky's Avatar
Amps · Volts/(1000·power factor)=KVA
Old 06-25-2009, 09:29 AM   #3
Depends on if it is single phase or three phase. If it is single phase:
(kVA x 1000)/volts = amps
For three phase:
(kVA x 1000)/volts x 1.732 = amps
Power factor is only important if you convert kVA to kilowatts.
Old 06-25-2009, 04:48 PM   #4
thanks guys. so what will the power factor be if you were to do the calc from amps to KW . is it 0.9 or is is something else.
Old 06-25-2009, 05:15 PM   #5
depends on the equipment. Motors usually have the PF marked on them (in the U.S. anyway).
Old 06-28-2009, 02:51 PM   #6
Can't quite remember but isn't KVA basically power but with losses included?
ie
P=I*V
KVA=I*V*0.9 (as a rule of thumb)
Doc
Docara is offline   Reply With Quote
