UK LED Tube Lights - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By Dark Knight
Old 01-19-2016, 05:39 AM   #1
simpledoug's Avatar
Lightbulb LED Tube Lights
Hello, I'm Doug from Simple Lighting based in Wirral, UK.
We've had a few customers asking us about LED Tube lights recently, and we put together a video and blog post about them.
I thought some of you might be interested in seeing how easy it is to swap fluorescent tubes for LED, it's becoming an increasingly popular alternative to fluorescent tubes, due to a number of economical and environmental reasons.
You can see the blog and video at this address: https://www.simplelighting.co.uk/kno...ghts-with-led/
simpledoug is offline   Reply With Quote
Old 01-19-2016, 05:44 AM   #2
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,314
Oh,
Are you referring to Light Emitting Decorations?
Old 01-19-2016, 05:52 AM   #3
simpledoug's Avatar
Light Emitting Diodes
Old 01-19-2016, 09:06 PM   #4
Rewards Points: 36
What's with the starter thingy? We have the LED tubes here as well but they just run off a regular T8 electronic ballast and all we do is swap the bulbs. Presto, done!
ElectricMetalTuba likes this.
Dark Knight is offline   Reply With Quote
Old 01-20-2016, 04:00 AM   #5
simpledoug's Avatar
You don't need a starter for the LED Tubes in our blog, a dummy starter is included with the LED Tubes so you don't end up with a dust collecting, unsightly hole in your ballast.
The Following User Says Thank You to simpledoug For This Useful Post:
Old 05-31-2016, 02:04 AM   #6
Rewards Points: 2,378
It's been my experience that LED tubes do NOT put out as much as a good condition working floro tube,
in fact the latest high output floro's have VERY high outputs.
Well in excess of any Led tubes.
the only real advantage of a LED tube is reduced power use.
Some of the latest designs have built in motion sensors
to reduce output when no one is around.
But if your after high output your better off sticking with floro tubes.
Old 11-07-2016, 09:10 AM   #7
Watt Pusher
B-Nabs's Avatar
Rewards Points: 436
Originally Posted by Dmitri View Post
Good work there, I love ikea-like instructions
It's missing the weird-looking amorphous person character scratching its head in confusion.
Old 03-15-2017, 09:16 PM   #8
there is ballasts compatible LED tube, just remove the starter and install a new LED tube, no need for a new starter.
FWLED is offline   Reply With Quote
Old 03-24-2017, 02:45 AM   #9
ElectricMetalTuba's Avatar
Rewards Points: 124
Discharge lamps cost way less. And have lower failure rate.
If I had to do endless rows of accent up lighting along a shopping mall corridor. I would not be using LEDs. Plus if you use 0-10VDC ballasts the energy savings is in daylight harvesting.
The environmental impact is about the same. They are both filled with toxic metals.
Then there is the semiconductor raw material sourcing. Filled with human rights violations.
Bottom line is LEDs are a better solution if they are designed with proper fixture designs with lensing.
Not trying to discount you. I like your idea. It does add a modernization effect.
ElectricMetalTuba is offline   Reply With Quote
Tags
led bulbs, led lighting, led tube
Low voltage landscape lights LED vs traditional keeko785 General Electrical Discussion 5 01-13-2016 10:05 PM
Workshop Subpanel - House lights dimming ispperformance General Electrical Discussion 1 01-06-2016 11:31 PM
120 washer lights dimming COSMOS275 Residential Electrical Forum 6 01-04-2016 11:40 PM
