Old 12-26-2007, 06:30 AM   #1
Default Low Voltage Lighting
Hi all, I have a lighting system which has three mains voltage exterior spotlights which are controlled via three seperate 12v PIRs. Trouble is the control unit which connects the two elements is caput........the transformer has given out. Could anyone advise where I might get a replacement control unit which will provide two or three zones and enable me to connect mains and low voltage?
rozentas is offline   Reply With Quote
Old 12-26-2007, 12:17 PM   #2
frank's Avatar
You could always rewire the 12 volt signal sections and install 230 Volt PIR units.Bypassing the existing interface unit.
Or. You can build your own interface unit. An electronic one via Farnell or Maplin Logic Controllers or semi mechanical with a relay switching mechanism. As for getting a replacement. Since you have called this forum the manufacturer must be out of business.
Low Voltage/ High Voltage MikeD NEC Code Forum 18 02-19-2009 05:17 PM
low voltage pool lighting rebel34 NEC Code Forum 2 08-06-2008 06:18 AM
Low Voltage Lighting Mountain Electrician General Electrical Discussion 10 10-21-2007 10:36 AM
Flickering Low Voltage lighting. thunderpaste General Electrical Discussion 14 09-15-2007 03:12 PM
Low Voltage Lighting joebell Lighting Design 1 09-09-2007 09:38 AM
