UK Power distribution in the UK - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By billn
Old 11-08-2015, 03:22 PM   #1
Rewards Points: 32
Default Power distribution in the UK
Does anyone have the time and energy to explain to this retired American electrician how your power distribution is arranged in the UK?
In North American practice the power is delivered with three High Voltage phase lines and a Neutral Conductor. The transformer that supplies an individual residence would be connected on it's Supply side between a single phase conductor and the Neutral. The connecting bushing for the Neutral end of the supply winding is usually uninsulated and the entire metallic enclosure of the transformer is bonded to the Neutral. The distribution Neutral conductor here is Multi-grounded. By that I mean that at intervals along the line and at every transformer the Neutral is earthed by connection to a variety of Grounding Electrodes. Some are driven rods. Others may be copper but plates on the bottom of the pole. Some are just the Grounding Electrode Conductor continued to the buried portion of the pole and wound in a spiral across the but of the pole.
My biggest question is about the Neutral Conductor of your utilities distribution system. Is the Neutral conductor solidly grounded (Earthed) in multiple locations or not? I am not asking about various kinds of protective devices that might conduct to earth during an abnormal condition such as a lightning strike to a line. Is the supply side of the transformer; in a neighborhood that is only single family detached dwellings; connected between a phase and the Neutral or is it phase to phase? Is one of the Supply conductors from the load side winding of the transformer Earthed? If it is earthed, is that done at the transformer, the service unit on or in the home, or were. Is the supply to an individual residence of ordinary size a single voltage? How many current carrying conductors; that being those that carry current under normal operating conditions; are brought to a single Service Unit?
I'm just idly curious you see now that I am retired and have time to wonder about such things.
Tom Horne
"This alternating current stuff is just a fad. It is much too dangerous for general use." Thomas Alva Edison
hornetd is offline   Reply With Quote
Old 11-08-2015, 08:57 PM   #2
Rewards Points: 150
Use the search tool to find the old thread below which may answer your questions.
The differences in our electrical systems
Old 11-09-2015, 07:34 AM   #3
Very Long Vacation
Rewards Points: 5,262
In the UK most public distribution systems are 3 phase 3 wire where a transformer steps 11kv down to 240/415Y 4 wire (Its really 250/433Y as based on the name plate with no load).
Old 11-09-2015, 07:40 AM   #4
Very Long Vacation
Homes get on phase, a neutral and sometimes a separate ground. Google TN-C-S, TN-S and TT earthing systems to get a basic crash course.
Old 11-11-2015, 02:16 PM   #5
Tony S's Avatar
Rewards Points: 82
Tom Horne
So like me youíre retired and interested in other distribution systems.
Iím willing to e-mail DNO (PoCo) design guides, I will not post them in open forum. PM me.
Iím English so what do I know?
Tony S is offline   Reply With Quote
The Following User Says Thank You to Tony S For This Useful Post:
Old 01-21-2016, 05:57 AM   #6
Rewards Points: 2,336
Yes !
Lots of regular earthing
Most poles would have neutral bonded
And all buildings also have ground rod.
Old 01-25-2016, 08:54 PM   #7
Tony S's Avatar
Rewards Points: 82
Originally Posted by dmxtothemax View Post
Yes !
Almost right
Wrong
Wrong
Old 01-25-2016, 09:28 PM   #8
Rewards Points: 1,702
Originally Posted by Tony S View Post
Almost right
Wrong
Wrong
No Ground Rod ?
What do you do for Lightning ?
Pete
pete87 is offline   Reply With Quote
Old 01-26-2016, 12:11 AM   #9
Rewards Points: 120
Didn't you know, they don't get lightning in the UK.
An acquaintance of mine in the UK says a lot of power is run from the substation (maybe he meant pole pig or pedestal?) to the residence. He stated that there is a grounding conductor at the substation, but none at the residence.
I have no idea about the veracity of his claims. He is a decade older than I am, so his mind may be even foggier than mine.
Ctsparky93 likes this.
billn is offline   Reply With Quote
Old 01-26-2016, 10:26 AM   #10
Tony S's Avatar
Rewards Points: 82
Originally Posted by pete87 View Post
No Ground Rod ?
Pete
Itís up to the DNO (PoCo) to provide an earth for TN-S, TN-C-S and PME supplies. TT supplies it is up to the consumer to provide an electrode.
PME is like your CNE system.
Residential areas donít have multiple small ďcansĒ but large local 11/.433KV units serving an underground network. The supply to my place is from a 1250KVA 11/.433KV 4.5% reactance substation about 500 feet away.
pete87 (01-29-2016)
Old 01-26-2016, 12:28 PM   #11
Rewards Points: 120
Yes, he told me that the sub-station to his house was well over 1000 feet away. He stated that the one supplying a theatre where he worked was even further.
Old 05-16-2016, 03:41 PM   #12
Rewards Points: 12
I am told that the only situation where an earth electrode is installed at the consumer's end is in remote rural sites. Many domestic installations are connected to the TN-CS system, where the DNO connects the consumer's earthing terminal to the neutral conductor.
LMacaulay is offline   Reply With Quote
Old 05-28-2016, 10:35 AM   #13
Tony S's Avatar
Rewards Points: 82
Living in Scotland you should know the supply situation for remote areas. On the isles I’ve seen CNE which is unusual for the UK.
Old 11-07-2016, 05:56 PM   #14
Rewards Points: 432
Saw what by accident?
Essex is offline   Reply With Quote
Old 11-07-2016, 08:21 PM   #15
Speedy Petey's Avatar
Rewards Points: 1,780
Gibberish replies to get you to look at his spammy profile.
ďThe good thing about science is that it's true whether or not you believe in it.Ē
The Following User Says Thank You to Speedy Petey For This Useful Post:
Essex (11-08-2016)
Old 11-07-2016, 08:40 PM   #16
motherplucker
chicken steve's Avatar
Rewards Points: 3,310
Methinks one should start with Earthing Systems , as perspective, and ask from there.
And Pete, if you're on the job, know that the last go around with this was closed due to the 'pack mentality' of late here....
Essex (11-08-2016)
Old 02-16-2017, 10:46 AM   #17
Hey there,
Agree with @meadow.
Cheers,
Barry
barrydean is offline   Reply With Quote
Trailerized Power Distribution vinister Commercial Electrical Forum 19 11-30-2013 01:42 AM
Power distribution study electricalcj Business, Marketing, and Sales 2 01-15-2013 05:49 PM
Power distribution blocks jtashaffer Tools, Equipment and New Products 1 09-16-2012 11:13 PM
temporary power distribution vos General Electrical Discussion 13 05-10-2010 04:58 AM
Switchgear/power distribution Zog Site Help and Suggestions 8 11-19-2009 09:32 PM
