Old 08-04-2009, 03:04 PM   #1
Default sockets
can anybody tell me the distance between socket outlets on a 3 phase dis board
on opposite phases as i have come across it on a factory and the reg no if poss thanks
steve c is offline   Reply With Quote
Old 08-08-2009, 12:23 PM   #2
Hi Steve
I there one ? If there are sockets in a room say on different phases I've always used generic cover your ass sticker ' WARNING 415V Between points ...........
Personally I wouldn't be happy if they were within arms length (2m) but I have seen them 100mm
Sorry dont have the regs to hand
Matt
Docara is offline   Reply With Quote
Old 08-08-2009, 01:55 PM   #3
No matter how far away they might be, people can sill use items that are cord and plug connected. Having the sockets oriented far apart still doesn't prevent the appliances from being on top of each other. In my opinion, the appliance is much less safe, over time, then the socket itself. It's not like the electrons jump out of the socket holes, but appliances certainly fail due to age and abuse.
Old 08-09-2009, 05:29 AM   #4
Originally Posted by Docara View Post
Hi Steve
Matt
HI Matt
Thanks for the reply it is scarry that it would be done this way i have advised for the circuits be wired again from the origin of the supply
so each office as its own circuit from one phase
To reduce the danger to unskilled persons
steve
Old 08-16-2009, 04:30 PM   #5
Hi Steve
Why????
Don't forget it is NOT against the regs to have sockets on different phases within a room think of the loading and/or balancing of loads across phases - realisticly what are the chances that two pieces of equipment have faults at the same time that do not blow a breaker trip an RCD etc. The only realistic chance is that some prick takes of both faceplates and decides to touch something - Very unlikely.
To make you feel better think about installation of class 1 and class 2 cabling - they can occupy cable tray as long as there is a minimum of 50mm spacing
A warning sticker (as per the regs specific wording for this reason) is all that is needed
PS 400V not 415V as previously mentioned I forgot we are now buying our electricity from F******ing Europe
Matt
Old 08-17-2009, 02:02 PM   #6
Default sockets
hi matt
The offices are about 15ft sq with a wall between each one there is about
10 offices so i can balance the phases . on a ring circuit supplying two offices at a time as i said a 18way 3 phase cu it will also control the lighting on the shop floor taiking about european why did thay change
the colours from red yellow blue to brown black gray blue
when work on 3 phase in a old instalation plenty of stickers around the place now
steve
Getting a Feet to sockets Gavin Adams UK Electrical Forum 8 11-24-2008 01:32 PM
Remote control lights/sockets philip657 UK Electrical Forum 0 09-01-2008 09:28 AM
sockets in bathroom- canada colin General Electrical Discussion 7 07-24-2008 08:27 PM
sockets behind appliances in kitchens geoffsparks General Electrical Discussion 6 08-16-2007 05:38 PM
Sockets with RCD kevruta NEC Code Forum 2 02-26-2007 07:50 AM
