Old 02-08-2008, 02:06 PM   #1
junior member UK
Default Swa Tool In Professional electrician mag
Has anyone used one of theese Kew Teknik SWA stripper?
Does it work and does anyone know what sort of money are we talking about.
many thanks.
cornishsparks is offline   Reply With Quote
Old 02-10-2008, 12:33 PM   #2
frank's Avatar
I have ordered one. Will give feed back when it arrives,
Old 02-10-2008, 04:56 PM   #3
junior member UK
Cheers Frank im hoping they will do the job they say they do.Cant find any suppliers at moment that have any in stock dont want to order one without seeing it.
Old 02-10-2008, 05:38 PM   #4
52 gone, 53 arrived
Trimix-leccy's Avatar
Location: UK, by the seaside, besides the sea!! Home of the F1 Motor Racing WORLD Champion!! AGAIN!!!
http://www.sercal-testequipmentsales...pper-672-p.asp
I think I will have a go at making one! It only 'appears' to be a pipe cutter with a hacksaw blade instead of the cutting wheel
On the other hand it may be consigned to my pile of 'unfinshed projects' of which there are many
I am a confirmed gadgetteer. I have 2 lathes, milling machine, pedestal drills, linisher etc etc. Mig, Stick, Gas welders etc etc. I make [try to] Diving equipment, gadgets for work
Trimix-leccy is offline   Reply With Quote
Old 03-12-2008, 07:10 PM   #5
many thanks.
Bought one a month ago in WF. Cost about £18. Made off around 15, 2.5mm, 3-core armoureds and the blade was shagged (comes with 1 spare).
Did the job but I wouldn't advise using it to strip the pvc sheath under the steel wires(instructions suggest this), as you may damage the inner cores.
Overall I'd say it's worth having in the bag, although a little overpriced.
supasparx is offline   Reply With Quote
Old 03-12-2008, 07:23 PM   #6
52 gone, 53 arrived
I'm guessing that it will struggle with the AWA 400mm^2 singles on my next job then
Old 04-07-2008, 03:33 PM   #7
frank's Avatar
Well it arrived.
It works and that's all you can say. I shan't use it again though. The hacksaw is better and faster
Old 04-07-2008, 03:40 PM   #8
when i did swa cable i used a pipe cutter to cut the steal off and then a knice for the other bits
philip657 is offline   Reply With Quote
Old 04-07-2008, 06:20 PM   #9
"A" inside wireman
randomkiller's Avatar
I have used a Ridgid #20 tubing cutter in the past with a stainless steel cutting wheel that had to be ordered seperately. I'm sure you can find them online.
"One Nation Under God"
Old 04-08-2008, 04:34 PM   #10
Don't like know it alls
I too tried one of these swa strippers and can't say i was over impressed,i much prefer tha hacksaw and is a lot quicker as you say.
I donated mine to one of the lads.
Chris
chrisb271 is offline   Reply With Quote
Paging all tool hounds, tool porn inside NC_Electrician Tools, Equipment and New Products 123 01-24-2009 11:27 PM
New Tool Mike228 Tools, Equipment and New Products 5 06-17-2008 10:05 PM
electrician hand tool usage wl7bm Workplace Safety 7 06-04-2008 09:33 PM
New Electrician Tool Help ben30205 Tools, Equipment and New Products 17 05-04-2008 02:41 PM
BAHCO Professional 9 piece Electricians Hole Saw Kit gatti Electrician Swap 3 04-29-2008 06:03 PM
