UK Is There a Difference Between UK & Australia? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By Mshea
Old 10-31-2015, 11:53 AM   #1
Rewards Points: 150
Default Is There a Difference Between UK & Australia?
I am an American electrician and have had the opportunity to work on British electrical systems. Aside from the UK using British Standard and the Australians using Australian Standard, is there any real difference? Thank you
Old 10-31-2015, 12:56 PM   #2
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 130
I would say yes, and the Australians have their own code book as well..
CS2 Flat Rate
The Following 2 Users Say Thank You to Black Dog For This Useful Post:
Bird dog (10-31-2015), donaldelectrician (05-03-2016)
Old 10-31-2015, 06:06 PM   #3
Very Long Vacation
Rewards Points: 5,262
There is some difference, but the greatest is between the UK and North America.
Old 10-31-2015, 06:07 PM   #4
Rewards Points: 624
No difference, other than they are different countries with different laws.
ELECTRICK2 is offline   Reply With Quote
Old 11-11-2015, 05:00 PM   #5
Tony S's Avatar
Rewards Points: 82
Big difference.
Bird dog, get a copy AS/NZS3000.
I’m English so what do I know?
Tony S is offline   Reply With Quote
The Following 2 Users Say Thank You to Tony S For This Useful Post:
Bird dog (11-11-2015), chicken steve (11-12-2015)
Old 11-11-2015, 09:57 PM   #6
Rewards Points: 2,336
It all depends on what you call
"Real difference" ?
Please elaborate ?
Yes we are simulair !
But as all electricians know
The devil is in the detail !
Old 11-12-2015, 12:01 AM   #7
Rewards Points: 3,364
No difference, guns are banned in both countries.
LawnGuyLandSparky is online now   Reply With Quote
Old 11-12-2015, 06:52 AM   #8
motherplucker
chicken steve's Avatar
Rewards Points: 3,310
Having been briefed* in each doctrine, i think i can honestly say they're both nowhere near the copperholics** we NEC folk are.....
*enough to understand the basics....thx to Tony & UK crew....
**there should be an 800#....
Old 11-12-2015, 12:16 PM   #9
Rewards Points: 2,746
Much better surf in Australia. Makes a big difference to quality electricians.
Old 11-12-2015, 02:31 PM   #10
Rewards Points: 150
"Real difference" ?
Please elaborate ?
1)Is your distribution voltage 400/230, 3phase, 50hz?
2)Does the utility provide a neutral and ground wire?
3)Do you protect everything with a RCD(residual current device)?
4)Do you use ring circuits?
5)How often do you perform impedance testing?
6)How often do you test the trip curve on a RCD?
7)Do you use plastic conduit in houses?
8)What kind of conduit/ cables(SWA cable, Steel Wire Armoured) do you use in commercial and industrial settings?
9)Do you have fuses(13amp) in your plugs?
Thank you
Old 11-12-2015, 08:50 PM   #11
Wink
Thank you
1- technically it is 230/400 but in reality its 240/415.
2 - utilty provides neutral but not earth, all poles have neutral bonded
So each house /building has ground rod.as do all.poles.
3- any new instals require rcd's on.power circuits only,
Rcd's on other circuits such as lighting is encouraged but not mandatory.
4- ring mains are not used, but I have seen them in older buildings very rare.
5- not very often, probably only for inspection testing.
6- depends on classificaton, varies from every 6 months to every 2 years.
7- yes. But mainly.if.it is exposed. If it is inside a timber ir plaster wall usually no
If inside a cińder block wall yes.
8- mosty pvc conduit, high density in some applications, armoured used mainly
In industrial, or domestic if subject to rough use.Mostly copper wire no alum.
9- no fuses in plugs.
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 05-02-2016, 06:44 PM   #12
Rewards Points: 432
Yes. Australia is full of convicts. ��������
Essex is offline   Reply With Quote
Old 05-02-2016, 06:54 PM   #13
Rewards Points: 1,810
I have seen that India and Qatar both use the British system but in execution there are vast differences. Kind of like Mexico. their code is very similar but no one installs it that way.
donaldelectrician likes this.
Old 05-02-2016, 06:57 PM   #14
Rewards Points: 432
I know that Australia accept UK electricians for a Visa so it cannot be that different. There is a license to practice however within Oz dependant on what state you want to work in.
Old 05-02-2016, 08:51 PM   #15
drsparky's Avatar
Rewards Points: 276
Everything is Australia is upside down.
Old 05-03-2016, 06:31 PM   #16
Rewards Points: 1,539
Having not worked there .
I will guess the Wiring .
Don
donaldelectrician is offline   Reply With Quote
Old 05-03-2016, 10:44 PM   #17
All Right .
Check the Internet , lots of info . Here is 2007
http://r.b5z.net/i/u/10115377/f/Aust...ncl_amdt_1.pdf
They have 50hz system , they loop through terminals ,
http://www.techstreet.com/publishers...S2saArQF8P8HAQ
Teck Store
Don
What is the difference between Instrument Transfer Switch & Auxillary Selector Switch netfreak General Electrical Discussion 2 07-21-2014 11:38 PM
Difference between RTU & PLC and also SCADA VS HMI Heartnet PLCs, VFDs, Motors and Controls 16 04-04-2013 08:56 PM
Difference on Canadian & U.S. licensing personal Off Topic (Non Trade) 13 01-30-2009 11:51 AM
Difference between a PT & CVT speedtronic General Electrical Discussion 1 10-27-2008 07:02 AM
Difference between FVNR & FVR MCC Starter? ms9 General Electrical Discussion 2 06-02-2008 10:42 PM
