Old 05-16-2008, 04:45 PM   #1
Default Variable frequency inverter connections
I am looking to replace a 7.5KW (10HP) AC 3 phase motor and Variable Frequency drive. I have selected a Eurotherm 650 3 phase 7.5KW and a SEM 7.5KW motor as they were on stock locally, I was wondering how should the motor be connected, should it be wired star or delta. Any advice much appreciated.
Charlie.
charlietech is offline   Reply With Quote
Old 05-16-2008, 05:07 PM   #2
Electrical Technician
chrisb271's Avatar
Check the motor rating plate bud,it will tell you the connection you need.some people seem to think they all need conneting Delta but this is not so.
I always use SY to connect motors to VFD's , make sure you bond the braid to earth if you use it and check the VFD's manual for max distance of cabling to motor.
Chris
LIVE EVERYDAY AS THOUGH ITS
YOUR LAST
AND ONE DAY..........
chrisb271 is offline   Reply With Quote
Old 05-16-2008, 06:10 PM   #3
chrisb271's Avatar
heres a bank of 30 vfd's i've just put into service at a local recycling plant
YOUR LAST
Old 06-09-2009, 06:57 PM   #4
Chris
I Have come up against the same problem. The motor rating plate gives values for Star and Delta but does not tell you which connection to use with the Inverter, neither does the Drive Manual.
Big Harry is offline   Reply With Quote
Old 06-09-2009, 07:37 PM   #5
Charlie.
Well wire it up delta heres why STAR /DELTA star is reduced voltage start and delta is full voltage applied to motor meaning wire up your motor for a delta full running tap .
Thats why they made freq drives to not have a need to star start /delta run it kinda ramps up the motor speed for you .
Dont know what or how your drive is made or any info about it ?
What is your type of drive ? Take care
Old 11-02-2009, 03:07 AM   #6
I think it's better to ask your supplier for this technical information.
acdrive is offline   Reply With Quote
cleaning buss connections sparky970 General Electrical Discussion 8 09-03-2008 08:21 AM
Inverter Baud Rate? Mackie General Electrical Discussion 15 08-30-2008 12:45 PM
DC - AC Inverter / Bypass Concern ohmontherange General Electrical Discussion 2 06-07-2008 11:32 PM
12V Lighting Connections megavolt Lighting Design 11 04-18-2008 07:42 PM
You Just Gotta Tighten Those Connections! brian john Workplace Safety 8 03-20-2007 06:02 PM
