Originally Posted by wildleg
electrician's qualifications: not dead yet
tool list: screwdriver, pliars
education: not dead yet
(by the way, for your location, that's top notch work ! )
Roger That! The lack of knowledge or qualifications for those who are not from the UK and USA is hard to believe! I asked an
electrician from Jordan about this and he looked at me as if I was crazy!
The ways in which unlicensed or certified persons work here in the Middle East is scary.
I have video clips and images that will prove my point; and I will be sharing them when I get home next week and in the coming months.
I watched some "electricians"
working on some fixtures under a car port at the dental clinic and they were installing 3 wires to be run into the so called raceway that is nothing more than a skinny tube like a broom stick handle, any way he was taping them together before feeding them in the tube!
The circuit was 20 amps, 230V, single phase using two wire and the colors were Brown,(Hot Leg), Blue (Neutral) and Red! I asked why aren't you using the Green with Yellow stripe instead of Red for the Earth (EGC) conductor and he looked at me as if to say, what's your problem we do this all of the time!
It was not work under my watch so I put the pictures into my library for future use and will show this one soon.
Were you an Expat?
