Old 10-12-2009, 12:40 PM   #1
Default Wondering about cable and voltages used across the pond
HI
My name is jon and I have only ever apprenticed-Jman and finally mastered(3yr as Jman with 2more tests) in Alberta Canada. I work mainly Industrial(SawMill) and high voltage (we have a thermal plant that burns wood byproduct), I used to work more res/comm when I apprenticed.
Anyways here in Alberta and pretty much everywhere else in Canada, we use NMD90, NMWU75 and PVC, with very little ridgid(O/H Service Mast) conduit for Residential, and Bx or AC90, Emt, DB2, Pvc, some ridigid for commericial, and Cable Tray for Teck90, ACWU, ACIC or Ridgid Alum for Industrial, then over head we use triplex or quadex(LV), or single ACSR(HV) and then USEb90 directburial, RW90(has to be in pipe)(LV) or URD Primary (HV) for underground.
I'm intersted in UK or Europe what cable or conduit systems do you use. And for what purpose, I know your wiring is different as you use a series ring system but then you have 240/380 compared to:
here all single family dwelling is 120/240 single phase split only up to 200amp you can go 400amp with special permission, with maybe a condo being 347/600 wye vac 2000amp serivice with drop down trannys for 120/208vac for the individual suites and they would be 60 or100amp. most commerical is 120/208 or 347/600 and most indust is 480 delta or 277/480 wye, with larger motors 4160 or 7220 or 13.8kv 14.4 kv or 25kv. Biggest low volt serivce(less than 750vac) is 6000amp biggest on the site I work 4000 amp PDC(power distrubition center)with several 3000amp. 7 of these huge services with many smaller through out the site.
Also do you just have 400volt or is there a higher industrial volt around 600? we used to have this old 416vac but it mainly gone in the civil areas, I think the military still uses it.
Also what is the average SFD (home) service? ours is 120/240 100amp and generally more and more underground with a little overhead in rocky or older areas with existing utilities.
THANKS
jontar is offline   Reply With Quote
Old 10-12-2009, 01:15 PM   #2
Hack and Rat all in one
Peter D's Avatar
A word of caution - when using this kind of terminology it's very likely that anyone outside of Canada or the U.S. is not going to have the slightest clue as to what any of that means. Even us Americans, though we use the same material, don't use many of those descriptions for them, like NMD90 or Teck90, ACWU, ACIC, etc. So while you may be speaking English you will likely be speaking a totally foreign language to someone from the UK.
Peter D is online now   Reply With Quote
Old 10-12-2009, 02:35 PM   #3
Toronto Sparky's Avatar
Good point! I've noticed a lot of different terms even between the U.S. and Canada.. Also in reading some of the U.K. posts, for the most part I get lost in the terms.
Don't fight .. Play nice!
Old 10-12-2009, 03:10 PM   #4
Peter D's Avatar
So, just for the sake of international unity, I'm going to attempt to translate:
Canadian / American
NMD90 = NM-B or Romex
NMWU75 = UF-B
AC90 = AC (BX in both countries apparently)
Teck90 = MC
RW90 = THHN/THWN
ACWU = ?
ACIC = ?
This still doesn't help anyone from the U.K. though.
Old 10-12-2009, 06:37 PM   #5
52 gone, 53 arrived
Trimix-leccy's Avatar
Location: UK, by the seaside, besides the sea!! Home of the F1 Motor Racing WORLD Champion!! AGAIN!!!
As a UK Spark of in excess of 35 years I can only understand the 'V' for voltage....as for the rest of it
same as me talking of
PILCSWAC
PYRO
MICC
SWA
Egatube
Dryliners
Chocboxes
Metaflex
Apaptaflex etc etc etc......
2 Nations divided by a common language
I spend more time Googling the terms than reading the posts
Trimix-leccy is offline   Reply With Quote
Old 10-13-2009, 12:27 AM   #6
Pyro I know..
Old 10-13-2009, 12:29 AM   #7
Peter D's Avatar
Pyro I know..
While we are at it, what is ACIC and ACWU?
Also, what do you call single conductor stranded or solid wires? T90? We call it THHN/THWN.
Old 10-13-2009, 12:37 PM   #8
Yes THHN or RW90 or T90 or TWN75 is pretty close to all the same, we sometimes also call it x-link its can be pulled into conduits, flexes, coreflex(PVC Flex), DB2, ETC, It can also be run between poles for secondary runs(1/0 and bigger) instead of triplex or quadex, or sometimes we use it to go from our ASCR on high voltage poles to the cutout and from the cutout to the h1 bushing on a single phase split can. I know its only rated for 600v or 1000v but thats what we do, you would still have to pull cut out and then live line clamp if you were in 2ft of the cable on a pole, to climb around it unless you were in a digger truck with gloves and sleeves.
ACWU= Amoured Cable weatherproof/underground its part way between AC90 and Teck90(MC) its got a thermoplastic outer casing by not the inner one on teck
ACIC= Amoured cable instrumention/control you can got it up to 50 conductor but only in #16awg for PLC control wiring and fuses at 5amps or less off the output cards on the PLC rack.
As for the rest your right or close enuff
AC90(BX) amoured cable
NMD90(romex) non-metalic damp
LVT low voltage t-stat 24vac and less
NMWU(UF) non-metalic weather/undergorund
USE90 underground service entrance
RW90 (THHN) i forget the r but w weather you can get direct burial rwu90 weather/underground
teck90(MC) there is no brake down for teck it was developmented for the TECK mining company for use in there mines back around mid 80s to early 90s, now used in oilfeild, sawmill, mining, farm, some times underground feed to garages from single family dwellings its probably the best cable in canada it has a outer thermoplastic then an amour then a inner thermoplastic then the wire, except in the 5kv and 25kv versions then is addtional coverings.
Old 10-13-2009, 05:06 PM   #9
52 gone, 53 arrived
one conductor [stranded or solid] with an isulated cover?....singles
SWA
SY flex if the armouring is steel and CY flex if it is tinned copper
Weird stuff this elektrickery, touchwood
Accident at work got me wondering headrec Workplace Safety 96 08-21-2009 09:43 PM
New guy wondering how to get in. johnciv6 Introductions 9 08-03-2009 07:54 PM
Wondering how that works... waco General Electrical Discussion 8 07-31-2009 11:59 AM
pond fountain berkey General Electrical Discussion 0 06-01-2009 11:04 PM
Across the Big Pond Question John General Electrical Discussion 14 05-21-2007 11:07 AM
