Go Back   Electrician Talk - Professional Electrical Contractors Forum > Community > Union Topics
Old 11-05-2009, 11:09 PM   #1
Default Switch locked out...still shocked.
I know that this is an unusual post/thread. But has anyone been shocked, even with the disconnect turned off and locked out?
Old 11-05-2009, 11:12 PM   #2
EDM
EDM's Avatar
Of course, anything from capacitors to bastard splices down the line.
What does this have to do with union topics?
I'm going back to work on Friday, no more time for foruming. Bye everyone!
EDM is offline   Reply With Quote
Old 11-05-2009, 11:12 PM   #3
Licensed Journeyman
nolabama's Avatar
No I have not, and the only situation I can see where this would happen is if the circuit was feed from two directions. Highly unlikely.
Old 11-05-2009, 11:13 PM   #4
Licensed Journeyman
nolabama's Avatar
I stand corrected - did not consider capacitors.
Old 11-05-2009, 11:15 PM   #5
Seen your member
Not when the circuit was off and locked, but power to the building turned off:
Large wires are the mains coming in. Go figure.
Probably some rat wired it.
Old 11-05-2009, 11:15 PM   #6
cdnelectrician's Avatar
Wouldn't you test the circuit in question even if the switch is locked out before putting your hands anywhere near it?
Old 11-05-2009, 11:16 PM   #7
How did this happen????
Old 11-05-2009, 11:17 PM   #8
Default locked out...still shocked
I am really into the safety at our plant. Sharing experiences could possibly enlighten others as to the possibilities that seem impossible. That's all.
Old 11-05-2009, 11:21 PM   #9
EDM
EDM's Avatar
All I am saying is that you should have put it in one of the electrical forums.
Old 11-05-2009, 11:23 PM   #10
Default Locked out...still shocked
Maybe you are right. Have you ever experienced a situation such as this?
Old 11-05-2009, 11:25 PM   #11
Licensed Journeyman
nolabama's Avatar
This is not in the safety forum?
480 - barring a rat wiring the house, how did this happen?
Old 11-05-2009, 11:36 PM   #12
EDM
EDM's Avatar
Such as what?
Old 11-05-2009, 11:42 PM   #13
It seems simple enough to me now but when it occurred it seemed a bit strange.
I was working on an underground sump pump at a power house. It was a pit out in the open. The service drop was about 100 yards from the pit; rest of the way...underground. I turned the disconnect at the drop, off and locked it out. At the pit I was getting ready to verify that the supply was, indeed OFF.
Somehow my knuckle contacted the line side of the maint. disconnect and I felt a definite shock. I brought my simpson meter over to measure. On the line side of the maint. disconnect, I had something like 80 volts on the A phase...95volts...on the B phase, and 95volts on C phase.
I went over to the service drop and opened the disconnect that I had previously LOCKED OUT. It turned out to be a FUSED disconnect. Some water trickled out but what I noticed was the large amount of condensation all over the inside of the disconnect, including the fuses.
I measured the LOAD side of THAT disconnect and the voltages were the same as before...with it locked out.
The moisture had become a Path, of sorts with very low current carrying capabilities, but a good shock.
Old 11-05-2009, 11:46 PM   #14
Seen your member
It was in a duplex, and the meter was pulled for the one side I was replacing the panel in. I can only assume there was a circuit that was tied into both panels so both tenants paid their half for the house lighting.
I didn't want to bother finding out, so I just capped off the hot and left it in the new panel.
Old 11-05-2009, 11:50 PM   #15
Absolutely!
Old 11-05-2009, 11:54 PM   #16
Licensed Journeyman
nolabama's Avatar
Well, clearly no union man wired that duplex.
I once had a carpenter tell me the first thing he does when renting a new apartment is to turn all the breakers off and see if any outlets are still hot. If he found one he would run an extension cord to his fridge.
Old 11-05-2009, 11:57 PM   #17
He WOOD.
Old 11-06-2009, 12:08 AM   #18
EDM
EDM's Avatar
I had a friend who did the EXACT same thing, only he ran a cord to his window air conditioner and blasted it at 65 degrees 24/7 for the whole first month he was there (it was August).
His bill was over $400 (it's usually around $100 for that time of year in his size place).
We found out that altho that receptacle wasn't fed from the panel in his unit, it was fed from a panel downstairs that was on his meter and covered some of the circuits in his unit.
Old 11-06-2009, 12:19 AM   #19
Hahahaha oh sh!t
Old 11-06-2009, 07:07 AM   #20
drsparky's Avatar
I worked on a house that once belonged to a "wise guy", it had 20 two lamp flood lights with motion sensors covering the perimeter of the house. The new home owner wanted to remove them because they were ugly. I followed the conduit to the panel, shut off the breaker and they were still hot. I followed the conduit around the house and found the second panel. The security lights were fed from two panels both using breaker #1. I guess he was afraid of getting “whacked”.
Lineman shocked by 69,000 volts pudge565 Linework 27 12-16-2009 10:40 PM
Locked thread? egads Off Topic 14 10-25-2009 10:46 PM
Ouch it shocked me poke81 Introductions 5 03-30-2009 09:02 PM
Locked:Low voltage... leland General Electrical Discussion 9 10-03-2008 07:10 AM
Shocked from a chimney. JohnJ0906 General Electrical Discussion 10 05-13-2008 09:48 AM
