Go Back   Electrician Talk - Professional Electrical Contractors Forum > Tools, Equipment & Safety > Electrician Swap
Old 04-14-2009, 02:45 PM   #1
Default 20 Year old Business doing some spring cleaning
Hello all,
Our company, Sun Electric Inc., has been in business for 20 years. We are in a desperate need for some spring cleaning. We are going to list a lot of the stuff on ebay, but I thought we would check here first to see if anyone was intersted in the stuff we are getting rid of. Everything is new and most is still in a box. I have been taking pictures of a lot of the stuff so if you are interested in any thing, please email me and I will send you a picture or discuss what we are willing to sell it for (sparky@maysvilleky.net). Here is the items we are getting rid of:
  • Siemens type 1 enclosure (panel tub) - New (Dimensions 5.75" deep x 20" wide x 44" high Cat. #B44 (1 of these)
  • 18" x18" x6" Nema l Enclosures - New (2 of these)
  • 2.5" Short radius rigid factyory 90 degree elbows (5 of these)
  • 200 amp/240V General Purpose type 1 enclosure fusable Square D disconnects (New in box) Cat #D224N Series F01 (2 of these)
  • Siemens type 1 enclosure (panel tub) Cat. B68 - New (Dimensions 5.75" deep x 20" wide x 68" high) (1 of these)
  • Matching Door (Siemens, New) to above panel tub (1 of these)
  • Square D 60 amp 240V fusible disconnect type 1 series F3 Cat# H22N - New (21 of these)
  • Siemens 3 pole 30 amp 600V Nema 3R fusible disconnect Cat# HF364J - New Fuses included that are new as well (1 of these)
  • Siemens 3 pole 30 amp 600V Non-fused disconnect Cat# HNF361 - New (1 of these)
  • Siemens type 1 enclosure (panel tub) - New (Dimensions 5.75" Deep x 20" wide x 38" high) Cat# B38 (1 of these)
  • Siemens type 1 enclosure panel tub - New (Dimensions 5.75" Deep x 20" wide x 32" high) Cat# B32 (2 of these)
  • Milbank 125 amp 3R single phase meter bases - New (2 of these)
  • Allen dBradley 2 unit push button enclosure only - New Cat# 800H-2HZ(4 of these)
  • Square D 30 amp 240V non-fused safety switch, 3 phase - New Cat#DU321 Series E2 Type 1 Enclosure (2 of these)
  • Square D 30 amp 240V non-fused safety switch, 3 phase - New Cat# DU321 RB Series E2 Type 3R enclosure (1 of these)
  • Siemens 30 amp 240 V single phase fused disconnect - New Cat# NR321 Enclosure type 3R (1 of these)
  • Siemens type 1 125 amp 240V single phase indoor load center - New 2-spot Cat# E0408ML1125F (1 of these)
  • Midwest 100 amp 120/240V Type 3R Rainproof power outlet - New Model# U076C010 offers 1-50 amp 4-wire outlet, also 2-20amp 120V GFI (1 of these)
  • Simplex duct housing part# 4098-9681 (Smoke detector for duct work) - New (2 of these)
  • Siemens 3 pole 30 amp 600V heavy duty safety switch Nema 3R - New Cat# HF361J (1 of these)
  • Siemens 2 pole 30 amp 240V Heavy duty safety switch Mena 3R - New Cat#HF221NR (1 of these)
  • Square D I-Line bus plug 100 amp 3 pole 3 wire 600 V Cat# PQ3610G - New (1 of these)
  • Square D 100 amp 240V 3 phase single throw fusible disconnect Nema 3R - New Cat#H323NRB (1 of these)
  • Square D 100 amp 240V nonfusible disconnect type 1 Cat#DU323 - New (2 of these)
  • Siemens 100 amp 120/240 V "Value Pack" load center - New Cat# G2020B1100CP included are (6) 20 amp single pole breakers (1 of these)
  • 24"x24"x6" Stainless steel junction box with black plate - New (1 of these)
  • Square D I-Line busway tap box 225 amp 600V Cat#PTB302G - New (1 of these)
  • GE Current transformer 200:5 amp ratio Type JCK-3 Cat# 753X51G BIL 60KV NSV4.8KV 50-60Hz - New (1 of these)
  • GE Manual Motor starting switch 2 pole single speed Nema 1 start/stop Cat# CR101JA1A - New (1 of these)
Sun Electric is offline   Reply With Quote
Old 04-14-2009, 05:58 PM   #2
Unlimited Lic.Electrician
william1978's Avatar
Welcome to the forum.
Old 04-15-2009, 06:58 AM   #3
"A" inside wireman
randomkiller's Avatar
"One Nation Under God"
Old 04-15-2009, 12:14 PM   #4
$100 bucks. You pay shipping.
Old 04-15-2009, 02:24 PM   #5
$100 for which item?
Old 04-15-2009, 02:52 PM   #6
Seen your member
My guess he means all of them.
Old 04-15-2009, 04:02 PM   #7
Mountain Electrician's Avatar
My guess is he got that.
Old 04-21-2009, 11:34 PM   #8
$100 and I will cover the shipping...
Shaffer87 is offline   Reply With Quote
New business, please help. BroadviewElec Business, Marketing, and Sales 29 04-27-2009 12:24 AM
new year res paul d. Off Topic 9 12-30-2008 09:14 PM
cleaning buss connections sparky970 General Electrical Discussion 8 09-03-2008 07:21 AM
Business facts waco General Electrical Discussion 7 01-20-2008 05:12 AM
Truck cleaning randomkiller Off Topic 34 01-18-2008 08:05 PM
