journeyman toolset $185
was given this toolset from the school i used it on maybe 2 projects but ended up with a beautiful klein set
[/b]#ncvt-1)klein tools no contact voltage tester
(#1010) " " long nose multi purpose tool (crimper/stripper)
(#D203-8) " " 8 inch long nose pliers w/ side cutters
(#BD111) " " VACO Bulldriver phillips #1 driver
(#P12) " " " phillips #0 driver
(#A130-3) " " " flat head cabinet tip driver
(#581-9)Empire torpedo level
(#35-261)Ideal Ergonomic Hacksaw
(#7525)Empire powergrip 25ft measuring tape
(#420)Channellock 9.5 inch tongue and groove pliers
(#369) " 9.5 inch Linesman Pliers
(#338) " 8 inch Diagonal Cutting Pliers
(#4932)Great Neck 6 inch Double edged wallboard saw
(#66-090)Stanley 1/4" x 4" cushion grip flat head driver
(#65-902) " 2-Point x 4" cushion Grip Phillips® Screwdriver
(#66-091) " 5/16" x 6" cushion grip Rounded Blade ScrewdriverRugged (#DAMP60) General® CAT III 600v AC AMP Clamp Meter
(MRF 16S) Estwing 16 OZ sure strike fiberglass handle
CLC soft sided 67 pocket tool bag
