Go Back   Electrician Talk - Professional Electrical Contractors Forum > Tools, Equipment & Safety > Electrician Swap
Old 09-23-2010, 09:29 PM   #1
Question Looking for 08 nec code book
I am looking for 2008 nec code book. The libraries locally have had theirs taken. No local book stores have them. Tried buying them online used and they are just a few dollars cheaper than brand new. Don't want to spend too much in 2011 book will be outdated.
peeps1223 is offline   Reply With Quote
Old 09-23-2010, 09:34 PM   #2
Chief Electron Relocator
Try the local supply houses.
Old 09-23-2010, 09:37 PM   #3
REMOVED
robnj772's Avatar
Just wait and buy a 2011 then
robnj772 is offline   Reply With Quote
Old 09-23-2010, 09:39 PM   #4
william1978's Avatar
You should be able to pick one up at your supply house for less than 30 bucks now. I saw them for that at one that I go to.
Old 09-23-2010, 09:47 PM   #5
Smile
my test is scheduled for nov. 2010 based on 2008 nec. book. what are you calling a supply house?
Old 09-23-2010, 09:49 PM   #6
A place that sells electrical supplies. REAL electrical supply houses, not Lowes or Home Depot.
Old 09-23-2010, 10:13 PM   #7
electrick's Avatar
Sorry, TP in short supply here. used Ch.1-8 to wipe my couldn't figure out what they meant anyway!
electrick is offline   Reply With Quote
Old 09-24-2010, 02:17 AM   #8
then you need to buy the 08 code book, What kind of test are you taking that requires the NEC and you don't know what a " Supply house " is ?
user438 is offline   Reply With Quote
Old 09-24-2010, 02:23 AM   #9
They should make change in the new code article definitions
90.72 "supply House" Place where local Hill billy fks up even the simplest order, place where you need to check prices on a daily basis, place where sometimes they give free hot dogs. place where they insist that Home depot's parts are lower quality
Old 09-24-2010, 02:53 AM   #10
I void warranties
Jlarson's Avatar
Now that's funny.
The best never stop learning.
Jlarson is online now   Reply With Quote
Where in the code book....HELP! DaveP NEC Code Forum 21 05-13-2010 08:44 AM
NEC code book zen NEC Code Forum 10 05-01-2010 03:22 PM
where is NM-B in code book RICK BOYD NEC Code Forum 11 11-16-2009 09:24 AM
the best code book gstyle41 General Electrical Discussion 32 01-24-2009 12:36 PM
Code book vs. Code book "Handbook" shotdown General Electrical Discussion 14 09-10-2007 12:39 PM
