Go Back   Electrician Talk - Professional Electrical Contractors Forum > Tools, Equipment & Safety > Electrician Swap
Old 10-03-2009, 12:16 PM   #1
Rat Extraordinaire
Default Progressive 2003 Cable Fault Locator
Near-new Progressive 2003 cable fault locator.
You can see this is in 'good-as-new' condition... it's not torn up or beat to death. It works just fine as I have tested it a couple times.
It also comes with a home-made A-frame:
Yea, it looks home-made, but it does the job intended!
$425, shipped anywhere in the lower 48 states.
The transmitter needs a new battery as it doesn't hold a charge, but I will get one and install it before I send it out.... I thought I'd hold off spending money on that to see if someone was actually interested in buying this first.
I've using my other one several times to pinpoint (OK, not pin-point, but within ¼" of the actual fault!) broken and damaged cables more than enough times to pay for it several times over.
This would be a great addition to anyone's tool arsensal.
Old 10-03-2009, 02:08 PM   #2
What fault locator did you switch to? We are still debating on what one to order looks like I have my brother convinced into getting the 3m one.
Sparky480 is offline   Reply With Quote
Old 10-03-2009, 02:18 PM   #3
Rat Extraordinaire
I'm not switching. I've got two of these. I can only use one at a time.
Old 10-03-2009, 02:23 PM   #4
You got two hands dont ya?? lol
Old 10-03-2009, 02:25 PM   #5
Rat Extraordinaire
Uh, no.
Old 10-03-2009, 02:46 PM   #6
If you like the 3M Dynatel stuff, you'll like this tool from 480. It's essentially the same locater. If you know how to use one, you know how to use the other.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 10-12-2009, 11:10 PM   #7
Rat Extraordinaire
Sale pending.
Underground Fault Locator Sparky480 General Electrical Discussion 15 07-08-2009 10:48 AM
Buried cable fault locator tool? RomexJockey Tools, Equipment and New Products 11 04-21-2009 04:02 PM
wire locator superelec Tools, Equipment and New Products 2 04-21-2009 01:11 PM
911 locator switch Woodneye General Electrical Discussion 11 12-20-2007 10:41 PM
