6 Lead Motor - Electrician Talk - Professional Electrical Contractors Forum
Old 12-14-2011, 06:42 PM   #1
dronai's Avatar
Rewards Points: 3,337
Default 6 Lead Motor
I found this on another site. I figured someone here would know. Looks to be IEC standard, not Nema
We have a 125 HP, 3 phase, 480VAC motor that has six leads coming out of the motor. Two leads are labeled "U2", two are labeled "V2", and two are labeled "W2". So I have 3 pairs of leads with the same label on them. Checking resistance between any two of the leads labeled the same indicates no continuity. However, you can read continuity between a U,V,W set. This indicates to me that there are two independent sets of motor windings. The debate between my co-workers is how to connect this motor. The thoughts are to connect both wires labeled the same to a leg of 3 phase. The other is to only connect one set of windings to the 3 phase. By the way, the motor cover shows a connection diagram for 9 wires. Any help is greatly appreciated.
I walk around the jobsite like everything is fine, but deep down inside my boot, my sock is sliding down
Old 12-14-2011, 06:54 PM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
paging Motorwinder
Old 12-14-2011, 07:04 PM   #3
dronai's Avatar
Originally Posted by mcclary's electrical View Post
paging Motorwinder
Or The Frenchman
Click here
The Following User Says Thank You to dronai For This Useful Post:
frenchelectrican (12-15-2011)
Old 12-14-2011, 07:06 PM   #4
evil bastard
Rewards Points: 746
I've never seen this, but if I did, I would tie the matched pairs together, one set to each phase.
The Following 3 Users Say Thank You to mcclary's electrical For This Useful Post:
hardworkingstiff (12-14-2011), mattsilkwood (12-14-2011), Mr. Sparkle (12-14-2011)
Old 12-14-2011, 07:12 PM   #5
It's been a while since I've had to deal with that and I'm probably way off but I believe you do have two windings. Start and run. Usually these motors have parallel feeds. The draw for start up is much greater than run. There should actually be sensitive technology telling relays in which phase of the process the motor is in. I've run into this on fire pumps before. All technology was contained in the pump controller. Ok y'all go ahead and hammer me now
Gaterhater is offline   Reply With Quote
Old 12-14-2011, 07:23 PM   #6
Rewards Points: 12,280
I think you have a Single Voltage--External Delta Connection.
http://www.electricmotorwarehouse.co...n_diagrams.htm
Giving up on unbiased truth.
Old 12-14-2011, 07:26 PM   #7
The stiff may be correct
Old 12-14-2011, 07:27 PM   #8
evil bastard
Rewards Points: 746
You're describing a wye/delta starter, and the windings are not labeled the same. Think about it, how would you know which leads to attach to the delta contactor and which to the wye?
Old 12-14-2011, 07:43 PM   #9
Possibly. But I'm sure I've run across similar situation. Three leads and two sets. Had to pull out 500 and parallel smaller cable for start and run. Delta/ wye I've ever come across has specific diagram for both configurations, no leads labeled the same
Old 12-14-2011, 07:46 PM   #10
With all the advances in VFDs, do they even use Wye start Delta run motor controllers anymore?
Old 12-14-2011, 08:33 PM   #11
Motorwinder's Avatar
Rewards Points: 150
Finally a motor question.
Hook the wires marked the same to each other. U2 to U2, V2 to V2, Ect.. for each phase.
It's a star connected motor with the leads paralleled, so you can use smaller lead wire.
Next..
Motorwinder is offline   Reply With Quote
The Following 6 Users Say Thank You to Motorwinder For This Useful Post:
dronai (12-14-2011), Jtt123 (01-01-2012), mcclary's electrical (12-14-2011), micromind (12-14-2011), Mr. Sparkle (12-14-2011), Specialist (12-16-2011)
Old 12-14-2011, 08:40 PM   #12
Rewards Points: 150
I really am a motor winder BTW. This is the one I did today..
Back to the regular scheduled program..
The Following 10 Users Say Thank You to Motorwinder For This Useful Post:
76nemo (12-15-2011), Bulldog1 (12-14-2011), dronai (12-14-2011), Frank Mc (12-15-2011), frenchelectrican (12-15-2011), mcclary's electrical (12-14-2011), micromind (12-14-2011), Mr. Sparkle (12-14-2011), Pete m. (12-15-2011), stuiec (12-15-2011)
Old 12-14-2011, 08:43 PM   #13
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
Threadstoppa
ďDammit, Smithers, this isnít rocket science, itís brain surgery!Ē
Old 12-14-2011, 08:55 PM   #14
Rewards Points: 150
Originally Posted by nolabama View Post
Threadstoppa
Sorry couldn't resist. Like you guys that are proud of your trades, I take pride in my work.
The Following 9 Users Say Thank You to Motorwinder For This Useful Post:
76nemo (12-15-2011), Bulldog1 (12-14-2011), chicken steve (12-15-2011), dronai (12-14-2011), Jtt123 (01-01-2012), mcclary's electrical (12-14-2011), micromind (12-14-2011), nitro71 (12-15-2011), stuiec (12-15-2011)
Old 12-14-2011, 09:01 PM   #15
dronai's Avatar
I knew you would be the one to figure it out.
And it's not dual voltage, or Delta Start Wye run ?
Old 12-14-2011, 09:13 PM   #16
Rewards Points: 346
Next..
Exactly.
This motor is suitable for part-winding start, but not wye-delta.
Last week, I connected a couple of 450HP motors that had 4 sets of T1, T2 and T3s.
Think of it as 4 motors in one frame.
Big generators are like this as well.
The Following 3 Users Say Thank You to micromind For This Useful Post:
dronai (12-15-2011), Frank Mc (12-15-2011), frenchelectrican (12-15-2011)
Old 12-14-2011, 10:52 PM   #17
jmsmith's Avatar
There are still a lot of plants using both air and refrigeration compressors that use wye-start delta-run controls.
jmsmith is offline   Reply With Quote
Old 12-15-2011, 12:00 AM   #18
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Who is a stiff..?
Old 12-15-2011, 12:48 AM   #19
Rewards Points: 346
One reason is because old-timers can repair a wye-delta starter, but not anything electronic.
Old 12-15-2011, 12:52 AM   #20
jmsmith's Avatar
No..... In a lot of these plants, maintenance still goes by "If it ain't broke, don't fix it!"
new lead man rnr electric Residential Electrical Forum 178 07-18-2011 12:41 AM
Lead anchors for j-box Saloomen NEC Code Forum 45 07-01-2011 09:39 PM
Lead services Gamit Business, Marketing, and Sales 8 06-28-2011 09:05 PM
need help with a 12 lead motor ArcRedoubt PLCs, VFDs, Motors and Controls 10 06-15-2011 11:29 AM
Lead Paint Speedy Petey General Electrical Discussion 21 04-21-2010 12:30 AM
