Old 04-15-2009, 06:11 PM   #21
I used to work on a super calander made by Kliewiefers. Every thing in German. Unreadable shematics. Ladder logic written by Beer adeled Bavarian Bozos. Tech from Black Forest geeks. The same people who make German Poo Porn!!
iaov is offline   Reply With Quote
Old 06-10-2009, 03:05 PM   #22
We are still on the Siemens 555 and using Tisoft(dos based). We have 1 S7 200.
shorted is offline   Reply With Quote
Old 06-10-2009, 11:16 PM   #23
Arrow
I used to work on a bench with industrial electronics. I saw AB more than any other manufacturer. That could be nothing more than coincidence as I have never seen a routine problem with them out in the field
Old 06-11-2009, 09:16 AM   #24
Ouch. I converted our local community college's curriculum over to the AB back in '96 because they had PLC 5's and most people in our area use AB's. I guess you would have been the disappointed one in the class... My only problem with Siemens S7 is the support in our area - non existant. I actually went to our rep to try to work up a relationship since I had two guys that had spent the last two years doing all Siemens. Months later I'm still waiting for them to contact me back. Our AB rep is fantastic. The rep can make the difference in a product line.
Russell
Russell White, P.E.
Automation Technologies, Inc.
www.AutomationNC.com
www.PLCMentor.com
PLCMentor.com is offline   Reply With Quote
Old 11-16-2009, 10:54 PM   #25
Default AB sucks!
Originally Posted by Mountain Electrician View Post
Anyone else get frustrated as h-e-double hockey sticks with AB? Great products, but they can be overly complicated and a bit stingy with their PLC tech info. If you don't have a service agreement, forget it!!
Example: Emergency call-out for a fuse problem w/ a ControlLogix 1756 OA16 output card. I'm about 45 min away, so we start troubleshooting on the phone. The current problem (they've been working on this for 3 hours before they called me, so who knows what the original problem is) is the fuse light on the card is lit. The mill electrician has already called the equipment's OEM tech support and they said there is no fuse, just reset the module and go. Didn't work. WTF??!! I point out that if there was no fuse, there would be no fuse light. DUHHH!! Anyway, I tell him to pull the card and check the fuse.
By the time I get on site, they are taking the card apart and we find a blown fuse. I check each individual output for shorts or grounds, everythings okay. The outputs consist of solenoid valves, 1 per. Each output is w/ a 2 A fast blow glass fuse, and the output cards fuse is a 3 A slow blow. I force each output on individually, no problem. Turns out a program glitch (the machine is less than a year old, and they hadn't had this exact set of circumstances yet) is trying to operate up and down solenoids at the same time, and that's what blew the fuse.
Here's my b*tch...while I've got the mill electrician verifing field wiring, etc. I go online to AB's web site to check their knowledgebase. After 10 min of navigating, I finally find a forum with a thread topic similar to my problem, and guess what...it's locked, and you can only access it with a tech support agreement!
As expensive as this stuff is, you'd think they would be less stingy with the info. I've never had this problem with their drives support, in fact just the opposite. Wonder what's the deal?
They are by far the worst, they are the only plc vendor i work with that charges for tech support even siemens (just as expensive) will support you through the supplier you bought it from. AB is in buisness because it is speced by machine buyers not machine builders. (I'm a machine builder
smeric28 is offline   Reply With Quote
Allen Keys SAE/METRIC Gents Tools, Equipment and New Products 12 10-17-2008 11:11 AM
