Old 05-25-2012, 11:30 PM   #1
Default Analog pressure regulator...
Anyone got any specific recommendations for an analog pressure regulator that you've used successfully in the past? Application will be to regulate 150psi input pressure to the 3 - 30 psi range.
Old 05-25-2012, 11:59 PM   #2
Here is a link to a Bosch/Rexroth E/P pressure regulator. I have used several of these in the past and have always had good luck with them, as long as you have a CLEAN, DRY air supply.
There are ones that have a max input pressure of 10 bar, as well as 11 bar. Input pressure rating of 10 bar SHOULD do it, but I would go with a max input pressure of 11 bar.
http://www.boschrexroth.com/pneumati...F_g5166_en.pdf
Correction: I thought there was one with a max input pressure of 10 bar. After double-checking, I see that they jump from 8 bar to 11 bar.
eric7379 is offline   Reply With Quote
Old 05-26-2012, 10:50 AM   #3
Netree's Avatar
Festo MPPE.
Netree is offline   Reply With Quote
Old 05-26-2012, 12:41 PM   #4
Former sparky
Ever try these guys Mark? http://www.industrialcontrolsonline.com/company They have always steered me in the right direction.
three pole regulator: direction of current flow guyorf General Electrical Discussion 1 04-27-2012 06:18 AM
Analog multimeters - Still using one ? Why ? Aldem Tools, Equipment and New Products 11 04-23-2012 12:44 AM
Analog input interfering with analog output wagnersydnor PLCs, VFDs, Motors and Controls 17 11-04-2010 12:45 PM
Pressure relief valve and pressure relief device speedtronic General Electrical Discussion 1 01-27-2010 07:43 PM
Generator Voltage Regulator Mountain Electrician General Electrical Discussion 0 07-31-2007 05:39 PM
