Old 04-11-2012, 05:11 PM   #1
Default Cannot Add a rung of logic
I am trying to add a rung to a PLC5-60 in RSLogix and when I accept the rung edits I get the following error; Rung could not be inserted into the online processor! Insert instruction Failed: Ext Sts=0x0B Access denied- privilege violation. I have checked and there are no restrictions set up under passwords and privileges under the project tree. Has anyone seen this before?
pmaxwell is offline   Reply With Quote
Old 04-11-2012, 07:06 PM   #2
That's something that happens that is peculiar to PLC 5's. Upload a copy of the program from the controller, save it. Then, wipe the controller by powering it down, pull the battery, and short the battery contacts for a minute. Download a fresh copy of your program, then do your edits again.
By the way... is the controller keyswitch in program mode? Certain things you can't do on PLC 5's in rem/run. Stuff like creating new data table addresses, for one popular example.
pmaxwell (04-12-2012)
Old 04-11-2012, 08:19 PM   #3
It's telling you that your PLC is in the Run state. It can't let you add rungs to a PLC that is operating a process, otherwise the outcome becomes unpredictable. You have to put the CPU key switch into the "Program" position, which means whatever it is doing will have to stop. No way around that as far as I know.
Old 04-12-2012, 08:20 AM   #4
The processor is in remote mode and I have added rungs to the ladder in the past on this processor. I will try to blow the program and reload. I have 8 other processors that I can add rungs to in remote mode so it has to be some anomaly with this processor.
Thanks!!
Old 04-15-2012, 05:33 PM   #5
Thought I would share with you what the problem was. I was out of memory on the PLC. I only had one word of memory left. I deleted some unused data files and was able to add the rungs that I needed. Seems as though AB would give a more accurate indicator of this! Thanks for your help!!
need help with line logic white hawk General Electrical Discussion 5 07-26-2011 08:40 AM
Union Logic brian john Union Topics 36 07-11-2011 04:41 PM
meter hack logic? JoeKP General Electrical Discussion 19 02-08-2010 06:25 PM
I see no logic in this brian john Off Topic 42 08-22-2009 05:13 PM
Are they qualified? (applicable to relay logic technicians) wdestar General Electrical Discussion 19 08-29-2008 03:37 PM
