Originally Posted by Ferrari_man
Hello again.
I have tried to write to some of these companies but havent got some real answers.
But I was thinking about if it is possibly to control the VFD with -10V to +10V, which I also have available.
So it would be
-10V full speed reverse (and -5V is 50%)
+10V full speed forward (and +5V is 50%)
0V stop.
We have a lot of teco t-verter E2 series, so if they were able to do it, it would be great.
hoping for a reply
Ferrari_man
You can do it. Any decent VFD can perform this simple operation. Programmed properly it will do as you wish. I have some background with TECO. I do not remember if this series control has the functions you need. I can bet you will need a feed back device like an encoder. The drive has to know the direction the motor is in. And you need to program the drive to recognize direction in relation to the speed reference (analog signal).
Call TECO technical support at 512-218-7536. Ask for Bill Downs, Mike Cook or Dan Wolf.
I have not been in touch with these guys for a few years. You might be able to find at least one of them. If not ask for the drives specialist.
But you can do this. I have seen it done many times and have installed several drives using the reference voltage to determine direction and speed.
Just in case try these guys.
Baldor: Jeff Lovelace (479-649-5247) or Tommy Taylor (479-648-5704)
Weg Electric: (800-839-2529) Ask for the drives specialist.
ABB: Kathy Holmes (262-785-8538) Steve Weingarth (262-785-3200) or drives specialist.
Again. If you cannot locate these folks, ask for the drives specialist. I am retired now for almost five years.
