Old 04-29-2012, 01:09 AM   #1
Default Hydrovar password
It's a long shot, but does anyone know a backdoor password (4-digit number) to get into password protected menus of a Hydrovar drive if the password is no longer the factory default of 0066? Don't really want to do a reset to defaults, then the programming goes away. They particular model is an HV 4.075, but the front end on all of these Hydrovar drives is the same.
Old 04-29-2012, 09:30 AM   #2
Licensed Journeyman
nolabama's Avatar
Given the time of post, I would say youre in a jam.
Old 04-29-2012, 10:04 AM   #3
jrannis's Avatar
Start here and roll the numbers:
http://www.scribd.com/doc/971382/Pic...Common-Numbers
"When a your only tool is a hammer, every problem looks like a nail"
jrannis is offline   Reply With Quote
Old 04-30-2012, 12:06 PM   #4
Wish I could help. I had heard once that ITT was brand-labeling those drives from ABB and they are essentially the same guts as an ACS310, but I could find no corraboration for that anywhere. Even then, I no longer have an access point for info from ABB since the Baldor realignment (all the ABB drive reps were fired in favor of Baldor reps, in spite of the fact that some Baldor reps sucked). Let us know if you find it though.
Old 04-30-2012, 12:25 PM   #5
Marc,
I doubt you can do a system restore (defaults) without the password. This is the main reason I never use passwords. Use the factory settings and use other means to keep unqualified people from accessing the program.
If someone went in and changed it, you got a problem. You might need to replace the control board. I hope not, but you might have too.
Old 05-08-2012, 11:36 PM   #6
Thought I'd post here for posterity's sake.
The factory master password is 0726.
When you enter that password, you'll be able to scroll to the option to enter a new password, and it will show you what the original user password is.
The Following 3 Users Say Thank You to MDShunk For This Useful Post:
John Valdes (05-09-2012), nolabama (05-09-2012), The_Modifier (05-09-2012)
Old 05-09-2012, 01:01 AM   #7
How did you get it?
garfield is offline   Reply With Quote
Old 05-09-2012, 01:08 AM   #8
Originally Posted by garfield View Post
How did you get it?
I read the part in the manual where it says:
Your Goulds Distributor or Application Engineer will not be able to help you with programming problems if you have changed the password and lost it!
...and then I proceeded to call them and asked them for a password that will work. I don't take no for an answer.
That password also opens up some undocumented menus. Seems like they're menus for loading the firmware.
No Facebook Password, Teachers Assistant Suspended 360max Off Topic 23 04-05-2012 02:31 PM
Looking for a job? be ready to give up your face book password HARRY304E Off Topic 38 03-30-2012 08:44 AM
Saving password frank Site Help and Suggestions 12 03-10-2007 08:21 PM
