Old 05-17-2009, 11:00 AM   #1
Ant
Default I need help with a control wiring circuit (homework)
Here's the summary:
- A push button is used to start a supply fan (controller 1).
- A return fan (controller 2) is interlocked to start automatically with the supply fan.
- In the event of a smoke condition the fans shutdown automatically.
- The supply and return fans cannot be restarted until the smoke detector system is reset (a latching relay is going to be used).
- In the case of excessive smoke, an exhaust fan (controller 3) can be started but only if the smoke detector system has not been reset.
A need to create a ladder and wire diagram.
I'm having problems from the third step down.
Ant is offline   Reply With Quote
Old 05-17-2009, 11:02 AM   #2
Common setup. Google "ANSUL fan" and "FA Shutdown" or search on this site for "ANSUL".
Show us what you have worked up so far. Nobody's going to do your homework for you, but we can help you with what you have worked up on your own.
Old 05-17-2009, 12:46 PM   #3
Ant
Default This is what I have:
http://img190.imageshack.us/img190/6550/66698843.png
Old 05-17-2009, 01:28 PM   #4
I would love to help you but I have no idea how to add, delete or change anything in your drawing. Whats the format the drawing is in?
Old 05-17-2009, 02:18 PM   #5
mg42's Avatar
Send a message via MSN to mg42
Remove the two last lines you added.
In order to make your third Fan work:
-The smoke detector must be active
-The excessive smoke detector must also be active
Translate this into a simple ladder line
If the applicant is young, tell him he's too young. Old, too old. Fat, too fat. If the applicant then waits for three days without food, shelter, or encouragement he may then enter and begin his training
mg42 is offline   Reply With Quote
Old 05-17-2009, 02:21 PM   #6
Since I've never heard of an "excessive smoke detector", I suspect that you want to the extra extractor fan to come on with a manual pushbutton, or maybe a timer?
Old 05-17-2009, 02:38 PM   #7
Ant
I did the drawing in Windows Paint so I guess you can open it up with that.
Old 05-17-2009, 02:41 PM   #8
Ant
Yeah, separate from the supply and return air.
Old 05-17-2009, 10:44 PM   #9
mg42's Avatar
I don't know the name of the device that detects the excessive smoke from the regular smoke. So I called it the "excessive smoke detector"
Old 05-18-2009, 09:30 PM   #10
mg42's Avatar
So, how's that ladder diagram coming along?
Old 05-18-2009, 09:46 PM   #11
Ant
Default This is what I came up with:
http://img265.imageshack.us/img265/1642/project.jpg
Old 05-18-2009, 11:54 PM   #12
I see alot of switches(contacts) but no control to coils.
Assuming there is some,when the supply turns on where is the proof switch to turn on the return?
You are getting there,keep at it.
Old 05-19-2009, 04:54 AM   #13
Why is their a hand/off/auto in your diagram now? did you change the control specs?
Anyways, a normally closed contact could be placed before your fan 1 coil. If smoke detector detects smoke and opens the contact, fan 1 will de-energize and and the interlock will open, causing fan 2 to stop.
To run the exhaust fan, just put controller three in series with a normally open contact that closes when the latch is tripped, then in series with the fan coil.
Run the latch to a control relay to give you the contacts needed.
JElectriCC is offline   Reply With Quote
Old 05-22-2009, 12:01 PM   #14
I am now learning how to use Microsoft Paint. Thanks
Old 05-22-2009, 12:23 PM   #15
cdnelectrician's Avatar
Why is there a H/O/A switch? is it required? I built a similar system for a refrigerant exhaust system in a mechanical room. Except I used a 4 pole double throw relay in place of a latching relay.
Strange Voltages to ground on control circuit knights of 3 Commercial Electrical Forum 18 10-25-2009 04:43 PM
Homework help. k2x General Electrical Discussion 10 05-15-2009 01:37 PM
control 4 calimurray General Electrical Discussion 2 08-31-2008 02:39 PM
6 Drops per 15 A circuit/8 Drops per 20 A circuit. Whats your opinion? romexrocket NEC Code Forum 30 03-05-2008 12:36 AM
Wiring In Generator Control Switch limey_swindon General Electrical Discussion 1 01-07-2008 07:16 PM
