Thanks guys.
I had to unsolder that wire to slide the new sleeve on and had a bear of a time getting it reconnected. I did not see any other damage and replaced bearings before I took it back and got it installed.
The customer is a friend of mine and met me out in the boonies when I was installing it. He is a heck of a nice guy but overworked, most farmers around here are.
The mounting brackets and tensioners for the belt are just about on their last legs, but I got it in place and ready to run.
The sad part is that this problem with mice was due to him replacing that gasoline power unit with a new one last year and being in a hurry to get the irrigation running again. Because the new generator was on the opposite side of the power unit, his old LTFMC did not reach, so he paralled a couple of 12/2 NMCs to feed the electrical disconnect. He had the NMCs loose inside the 1" KO for the peckerhead and the mice moved in for the winter.
I know that this sounds like a case of "the stupid shall be punished", but he is not stupid, just trying to keep up with too much stuff and forgot to call us to make it right.
Anyway, thanks for your replies.
Rick
