Old 04-02-2012, 09:18 PM   #1
Licensed Journeyman
nolabama's Avatar
Default latch circuit
I have sometimes heard a circuit as being described as a latch circuit. This is not using latch relays. Can someone describe a simple latch circuit? A question I posed the other day here about ramp speed of VFD let me know exactly how lacking my ladder logic skills really are. Lucky for me I have had some time with an engineer on how he draws his circuits. Anywho I am puzzled by what is ment by a latch circuit.
nolabama is online now   Reply With Quote
Old 04-02-2012, 09:22 PM   #2
cog
stuiec's Avatar
Not that I know, but sounds like another way to describe a holding contact.
aaaaand I would be wrong.
. electronics Also called: latch circuit a logic circuit that transfers the input states to the output states when signalled, the output thereafter remaining insensitive to changes in input status until signalled againvb .
Old 04-02-2012, 10:59 PM   #3
Sounds like a holding contact on a motor starter, maybe?
Mulder is offline   Reply With Quote
Old 04-03-2012, 05:44 AM   #4
Frank Mc's Avatar
As the other guys have mentioned it sounds like a holding contact....I.E. When you press a start button...it will energise a relay/contactor and one of its contacts will short the start button causing the circuit to latch...Pressing a stop button (n/c) is normally used to unlatch the circuit...
HTH
Only our rivers run free
Frank Mc is offline   Reply With Quote
Old 04-03-2012, 07:57 AM   #5
Tom45acp's Avatar
Try this web page, about the 8th diagram down. I do not recommend using this diagram in real life as a broken wire in the stop button circuit will prevent you from stopping the motor. You would use a NC button with a NO (XIC) contact in the ladder diagram.
http://www.allaboutcircuits.com/vol_4/chpt_6/6.html
Sometimes I wonder whether the world is being run by smart people who are putting us on, or by imbeciles who really mean it.
Tom45acp is offline   Reply With Quote
Old 04-03-2012, 08:49 AM   #6
1,000,000th Poster
Big John's Avatar
Yeah, that's the most common type of latching circuit I can think of.
I'd describe it as a circuit that locks itself into a certain position, e.g.: When one of the NO contacts on a relay will feed power to the relay coil after it's initially energized.
-John
Old 04-03-2012, 10:25 AM   #7
Technically, a seal in circuit is a seal in circuit, a latch circuit is something different. But... A lot of people mistakenly call a seal in circuit a latch circuit, so you need to know the context.
A latch (latched) circuit would be one that retains its state regardless of power application. A seal in circuit will reset if power fails, that's why you use them on motor control circuits because for safety you DON'T want the motor to automatically restart after a power fail is restored (in most cases). You would use a latch circuit if you DO want the circuit to remain in its previous state when power is restored, for instance with a lighting circuit.
To do a true latch circuit, you need a control device that is mechanically bi-stable. A latching relay or latching contactor has a mechanical or permanent magnet that retains the state, so it needs to have 2 coils, a latch coil and an unlatch coil. There are also electronic circuits that will retain their state as well, but not forever. They usually rely on batteries or capacitors to maintain the logic (or restore it so fast that you can't tell). Technically though, a simple on-off selector switch is a latching circuit, it's just not one that you can energize electrically.
The other kind of logic circuit that people often misidentify as a latch circuit is a "flip-flop" circuit. That is one where you have one momentary control device like a push button, and you push it once to energize, then push the same device again to de-energize the circuit. This CAN be a latch circuit IF the control device maintains its state, but that is a separate issue because you can also have a flip-flop that resets on power fail too.
The Following 8 Users Say Thank You to JRaef For This Useful Post:
Big John (04-03-2012), dronai (04-03-2012), eutecticalloy (04-05-2012), Frank Mc (04-04-2012), mrmike (04-03-2012), nolabama (04-03-2012), Nuzzie (04-03-2012), Pete m. (04-03-2012)
Old 04-03-2012, 12:23 PM   #8
1,000,000th Poster
Big John's Avatar
Good reply. I didn't know there was a difference between mechanically held and electrically held.
-John
Old 04-03-2012, 01:38 PM   #9
Phosphate Coated
dronai's Avatar
With PLC logic you can program either way. I hear it called Latch, or seal in. Holding contact is the same as seal in.
“From the ages of 8-18, me and my family moved around a lot. Mostly we would just stretch, but occasionally one of us would actually get up to go to the fridge.”
Lighting Circuit off of a 32amp Ring Main Circuit? Galileo UK Electrical Forum 4 02-29-2012 05:58 PM
one circuit or two? goose134 PLCs, VFDs, Motors and Controls 7 09-23-2011 06:37 PM
6 Drops per 15 A circuit/8 Drops per 20 A circuit. Whats your opinion? romexrocket NEC Code Forum 32 06-11-2010 06:38 AM
Panel cover latch / lock Slider General Electrical Discussion 3 01-13-2009 07:55 PM
240 vs 120 circuit ?????? tlg7mm General Electrical Discussion 4 12-16-2008 06:42 AM
