Old 04-04-2012, 05:30 PM   #1
Phosphate Coated as of 05
dronai's Avatar
Default Re-establishing your PLC comm connection
Every time I lay off PLC training, I have a problem re-establishing my driver connection to RS Links Classic from RS Logix 500 starter-lite.
I've solved this before, this time I can't get it to run.
Any tips appreciated.
dronai is online now   Reply With Quote
Old 04-04-2012, 07:20 PM   #2
Sweet Tea Addict
Sawdust454's Avatar
First thing, unplug your comm cable from your pc, then open links, select drivers and stop and delete all drivers that may be running.
Now add a new driver that matches the plc you are connecting to.
Choose auto config. That should do it.
If not then post the model of the plc and what driver you are using.
Sawdust454 is offline   Reply With Quote
The Following User Says Thank You to Sawdust454 For This Useful Post:
dronai (04-04-2012)
Old 04-04-2012, 07:55 PM   #3
dthurmond's Avatar
Make sure you don't have a bad communication cable.I had one last month that was giving me problems linking up sometimes. New cable and it would link up everytime.
dthurmond is offline   Reply With Quote
The Following User Says Thank You to dthurmond For This Useful Post:
dronai (04-04-2012)
Old 04-04-2012, 09:15 PM   #4
dronai's Avatar
With the exception of unpluging the comm cable, this is what I've been trying to do, and it usually works. The message I'm getting reads Com2port conflict. Status Running ? I try and delete it and use Com1 on up, No luck.
I try a different comm, and the message reads Unable to open the specified COM port for configuration testing !
Old 04-04-2012, 09:34 PM   #5
dronai's Avatar
Allen Bradley Micro Logix 1000 - Using RS-232 devices - Selecting AB_DF1-1 as the new driver. That's always worked
Old 04-04-2012, 11:05 PM   #6
I've had the same error before. Are you using a serial to USB converter? Most of the time it just involves shutting the computer down and restarting linx. If your still having issues and port conflicts you may need to go to the device manager and pick a new comm port.
Glen Walker is offline   Reply With Quote
Old 04-04-2012, 11:11 PM   #7
dronai's Avatar
No serial to usb converter. I did all of the above. Maybe there is a new RS Links version and the driver won't sinc ?
The first response said to disconnect the cable. I've tried with the cable in, and disconnected, and rebooted several times ???
Old 04-04-2012, 11:47 PM   #8
There must be some other program that's using that comm port on start up. Have you checked in the device manager to see if the particular comm port is used in another program? Another issue I've has was linx running as a service, not allowing me to reconfigure a comm port.
The Following User Says Thank You to Glen Walker For This Useful Post:
dronai (04-05-2012)
Old 04-04-2012, 11:52 PM   #9
dronai's Avatar
I got it !!!!!
Yes it was exactly what you just said. I used a google search on the error message, and someone said the same tip. So used another port and a driver automatically loaded and said com 6. So I made sure to select COM 6 in the drop down and it worked !!
Communication link is sometimes a PIA
Much thanks to all
Old 04-06-2012, 12:45 AM   #10
Splash's Avatar
You could also uninstall the driver for the com port from device manager and then reboot. Rslinx is bad about taking over com ports and not releasing them.
Splash is offline   Reply With Quote
EBM estimating software (comm.) jhwhaley72972 Commercial Electrical Forum 0 03-17-2012 12:29 AM
Multigang dwelling/comm service berkey General Electrical Discussion 4 01-20-2012 09:37 PM
comm cable slaghammer General Electrical Discussion 1 10-20-2011 02:02 PM
Establishing / verifying <25 Ohm ground galanm Commercial Electrical Forum 7 05-04-2010 09:21 AM
45 Sound Comm tech apprentice mhlunsford Union Topics 2 12-28-2009 05:52 PM
