Reading high ohms through coil - Electrician Talk - Professional Electrical Contractors Forum
Old 08-30-2010, 11:56 PM   #1
Rewards Points: 2,000
Default Reading high ohms through coil
Today I was troubleshooting a small relay. Self contained one. Cube style. Was reading 2.2 M ohms through the coil. Thought the coil was bad but it functioned fine. Anyone know why I was getting a reading that high?
Old 08-31-2010, 12:04 AM   #2
Jlarson's Avatar
Rewards Points: 2,848
what voltage?
Jlarson is online now   Reply With Quote
Old 08-31-2010, 12:08 AM   #3
120 volt. I was really baffled.
Old 08-31-2010, 12:53 AM   #4
Jlarson's Avatar
Was it hooked up, and do you know what brand it was?
Old 08-31-2010, 12:56 AM   #5
Not sure, pulled it out. Tested it across the coil. 2.2 M Ohms. Same on some replacement ones we got. Wasn't really my rodeo. Was just there to help. Coil reading seems super high or wrong.
Old 08-31-2010, 01:00 AM   #6
Jlarson's Avatar
You sure it wasn't 2.2k cause at 2.2m that's the most energy efficient coil ever. I know a lot of relays have snubers and stuff in parallel but that wouldn't cause a higher resistance.
Old 08-31-2010, 01:09 AM   #7
I might have been K, i'm not keen on the Ideal meter I've got. We were going pretty fast to. Seems like Meg. That's almost a open.
Old 08-31-2010, 01:14 AM   #8
Rewards Points: 478
Some digital meters don't do well when measuring resistance across an inductive device when they're set to autorange.
Try it with the range manually set to 2K, 4K, or something like that.
Rob
Old 08-31-2010, 01:22 AM   #9
Jlarson's Avatar
I don't like the ideals I have seen stuff like this happen to them in the past.
Rob
Good tip for everyone to remember, I see auto range trip people up when they use logging multimeters a lot too cause some of them don't range fast enough to catch some quick events.
Old 08-31-2010, 01:24 AM   #10
This other coil I tested read 146 ohms I think. That sounded correct to me. Not the same model of cube though. Same pin out though.
Old 08-31-2010, 01:31 AM   #11
Jlarson's Avatar
The different 120 volt ice cubes I stock all fall somewhere in the 3 to 5 K range depending on model. At 146 that thing would be drawing like almost an amp.
Old 08-31-2010, 01:38 AM   #12
Wouldn't the lower ohms one have lower amp reading.. V=IR?
Old 08-31-2010, 02:00 AM   #13
Jlarson's Avatar
I couldn't find my scientific calculator what do you want from me here
V=IR
V=120
I = IDK
R= 146
120
---- = I
146
I = .82
V=IR
V=120
I= IDK
R= 2200000
120
----- = I
2200000
I= .000055
Right because to solve for I its I=V/R I could be wrong it happens a lot
Old 08-31-2010, 08:40 AM   #14
I think I was really tired yesterday. I woke up thinking how could I have that equation wrong. Higher resistance = less amperage like you are saying. Basicaly what I had was a very low amperage coil. I probably had 2.2K Ohms. I'm glad I got that sorted out. Was kinda bugging me. Thanks for the help!
Old 08-31-2010, 12:34 PM   #15
Introyble's Avatar
Rewards Points: 1,000
2.2K is pretty normal, 2.2 M is like OUTHEREMAN
I fear the Creature from Jeckyll Island
Introyble is offline   Reply With Quote
Old 08-31-2010, 07:50 PM   #16
Rewards Points: 77
guy's
don't forget about cold resistance to hot resistance. Example when you ring a 60 watt light bulb the resistance is 7 ohms. That would be 17.142 amps per bulb. the hot resistance is about .05 amps.
kielarsp is offline   Reply With Quote
Old 08-31-2010, 08:43 PM   #17
Rewards Points: 5,198
Originally Posted by kielarsp View Post
guy's
Tell us what is going on...why the difference?
Old 08-31-2010, 09:35 PM   #18
Rewards Points: 478
All conductors have lower resistance at lower temperatures. As temperature increases, resistance also increases.
Rob
Old 08-31-2010, 09:39 PM   #19
Jlarson's Avatar
Rob
But still a 146 ohm 120volt ice cube relay coil ain't right.
Old 08-31-2010, 09:42 PM   #20
Rob
Okay, you are are talking about a positive co-efficient of temperature.
Need help making a customer understand ohms law. captkirk General Electrical Discussion 36 02-02-2010 11:42 PM
Does a potential coil carry current? foolios General Electrical Discussion 3 01-17-2010 01:41 AM
Ohms(resistance) Testing wallace7777 Services and Service Equipment 19 11-23-2008 02:54 PM
dc coil ILSS General Electrical Discussion 5 04-05-2007 04:57 PM
