Old 05-11-2012, 01:51 PM   #1
Should be working
dronai's Avatar
Default Single Phase Motor replacement
1/85th of a horsepower !!
Old 05-11-2012, 10:15 PM   #2
erics37's Avatar
That's cute.
Old 05-12-2012, 01:35 AM   #3
Yep, cute little motor!
Those are almost always shaded-pole type. Very low starting torque, and about 20% efficient. But very inexpensive to manufacture.
Most of the failures I've seen are because the sleeve bearings went dry.
Some of these motors are impedance protected. They can be powered continuously with the rotor locked and not burn up.
In this case, the efficiency is reduced to 0%........
Lol.
Old 05-12-2012, 03:08 AM   #4
I call those "skeleton motors". I think it's either United Refrigeration or Johnstone supply that sells those bearing end pieces as replacement parts. They're hard to find, otherwise.
Old 05-12-2012, 09:47 AM   #5
Yep. RSD (Refrigeration Supplies Distributor) is another source if you have one around you, likely on the shelf.
Old 05-12-2012, 09:26 PM   #6
Should be working
dronai's Avatar
Lol.
Yep, that's my old bath fan motor. The bearings were stiff. It would get locked rotor and just buzz.
I was lucky a local suppllier that has everything stocked the replacement motor. $21.00
Old 05-12-2012, 09:37 PM   #7
1,000,000th Poster
Big John's Avatar
...Some of these motors are impedance protected. They can be powered continuously with the rotor locked and not burn up....
I was under the impression that was actually a function of all shaded pole motors. Are they actually adding a separate winding to the impedance protected ones?
-John
Big John is online now   Reply With Quote
Old 05-12-2012, 10:26 PM   #8
-John
It's the way most smaller ones are built. The larger ones (usually found on older furnace blowers) are not impedance protected.
Big John (05-12-2012)
Old 05-12-2012, 11:01 PM   #9
I void warranties
Jlarson's Avatar
The paint and texture on the bearing is a dead give away it was a fart fan motor
The best never stop learning.
Old 05-12-2012, 11:14 PM   #10
1,000,000th Poster
Big John's Avatar
So now you're gonna scrap the / and install one that's plain ol' 185HP?
-John
TOOL_5150 (05-13-2012)
Old 05-13-2012, 01:35 AM   #11
Should be working
dronai's Avatar
I tried to megger it, but no reading with the Supro ?
Old 05-13-2012, 01:37 AM   #12
Then it probably doesn't have a winding shorted to the laminations. There's many ways for a motor to fail. I thought you said yours just had locked bearings?
Old 05-13-2012, 02:05 AM   #13
Should be working
dronai's Avatar
I heard the noise of locked rotor sound ! So I thought it was shorted. So I meggered it. But later after I took it apart, I noticed how stiff the bearings where compared to the new one. After I read the comments here, It was just the bearings.
Old 05-13-2012, 07:08 AM   #14
Pure Evil
drsparky's Avatar
-John
Not big enough to power the fart fan after I eat pickled eggs, this GE 100,000 hp unit should do the trick.
The Following User Says Thank You to drsparky For This Useful Post:
Big John (05-13-2012)
single phase 7 lead motor n5i5ken General Electrical Discussion 3 05-08-2012 12:10 AM
460 v single phase motor mightyjoe PLCs, VFDs, Motors and Controls 10 02-06-2012 07:23 PM
single phase motor / 3 phase starter electric mike PLCs, VFDs, Motors and Controls 15 12-28-2011 06:01 PM
Single & Three Phase Motor Loads on Three Phase Circuit josefbartos NEC Code Forum 4 09-05-2010 01:31 PM
Is there a 15 hp single phase motor? ashveal PLCs, VFDs, Motors and Controls 10 08-11-2010 12:40 AM
