Single phase for/rev starter. - Electrician Talk - Professional Electrical Contractors Forum
Old 12-19-2010, 08:04 PM   #1
Rewards Points: 83
Default Single phase for/rev starter.
Anybody have a recommendation for a single phase forward and reversing starter? I see tons of three phase ones but not single phase.
Sparkee is offline   Reply With Quote
Old 12-19-2010, 08:26 PM   #2
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
looking around the net i found a solution -
I would use a single phase reversing motor contactor (sometimes referred to as a single phase reversing motor starter). This contactor essentially is two interlocked contactors. This allows you to "change" the wiring configuration of the motor and also open it up completely. You would wire in the L1, L2, and Cap to the top of both sides and then wire T1, T2, and T4 to the bottom of the first one (left side), then wire T1,T2, and T3 into the bottom of the second one (right side). Then you will use a 110VAC or 24VDC circuit to open the contactor, close the forward side or close the reverse side. The contactor should come with a diagram of how to wire this simple control circuit. In addition, be sure to order the contactor w/ 110vac coil or 24VDC coil to match your control voltages. If you do not have a 24VDC supply on your machine, then order a 110VAC coil, as you will surely have this available.
Old 12-19-2010, 08:27 PM   #3
Licensed Journeyman
nolabama's Avatar
http://cgi.ebay.com/Allen-Bradley-NE...item255fc86886
Old 12-19-2010, 08:29 PM   #4
Licensed Journeyman
nolabama's Avatar
also try a "drum" switch
http://www.grainger.com/Grainger/DAY...actors-_-2X440
The Following 2 Users Say Thank You to nolabama For This Useful Post:
Charlie K (12-19-2010), Sparkee (12-23-2010)
Old 12-20-2010, 07:51 AM   #5
Lite em up !
mrmike's Avatar
Rewards Points: 250
Originally Posted by nolabama View Post
This is a 3 phase reversing starter with a 120v coil, but I don't see any reason why one couldn't use one for single phase. You would use just one of the contacts on each. As far as the overloads on it you could bypass that part of it, just be sure you have the motor protected another way...................
As mentioned a drum switch would also work..........
mrmike is offline   Reply With Quote
The Following User Says Thank You to mrmike For This Useful Post:
Old 12-20-2010, 01:19 PM   #6
Rewards Points: 2,226
Siemens / Furnas Class 22 starters are available for 1 phase 3 wire 2 pole reversing operation. For example a NEMA Size 00 1HP would be a 22BP12AA81 with a 120/240V coil. I use them all the time for electric gate operators. In the above link they are on the 2nd page.
I have, in a pinch, downloaded their wiring diagram for the 1 phase version and used it to convert a 3 phase rev starter when they didn't have any available fast enough. But it does involve changing one of the Aux. contacts into a Power Pole. If you can figure out stuff like that it's not difficult, but it's not for the casual user.
Keep in mind that your 1 phase motor must be capable of being reversed, not all types are.
Single Phase and Two Phase Difference? Golden Arc General Electrical Discussion 6 11-07-2013 01:00 AM
460 3 phase & 110 single phase in 10*12*8 junction box is it legal? Calectrical NEC Code Forum 11 12-06-2011 02:12 AM
Wiring single phase to 3 phase bimmer General Electrical Discussion 8 09-30-2010 11:09 PM
Single & Three Phase Motor Loads on Three Phase Circuit josefbartos NEC Code Forum 4 09-05-2010 02:31 PM
three phase to single phase convertion. brick General Electrical Discussion 2 07-29-2007 08:55 PM
