speed control for a single phase motor. - Electrician Talk - Professional Electrical Contractors Forum
Old 12-30-2011, 04:32 PM   #1
Default speed control for a single phase motor.
Does anyone know if anyone makes a speed contoller to slow down or speed up a single phase motor up to 5 hp? Something like a vfd but not as complicated. I have seen one with like a speed pot on it before but don't remember the brand.
Farm Duty is offline   Reply With Quote
Old 12-30-2011, 04:53 PM   #2
Motorwinder's Avatar
Rewards Points: 150
AC motor speed is determined by the frequency and the number of poles.
A 4 pole motor running on 60hz will run at 1800 rpm. Therefore to change the speed on an AC motor, you have to change the frequency, or the number of poles.
VFD.
You might have seen a DC controller.
Easa Southwestern Chapter
Motorwinder is offline   Reply With Quote
The Following User Says Thank You to Motorwinder For This Useful Post:
sparky970 (12-30-2011)
Old 12-30-2011, 09:07 PM   #3
Netree's Avatar
You can do this with a "variac". Think also that slow motor is not cooled as well as fan make slower turns.
Netree is offline   Reply With Quote
Old 12-30-2011, 09:33 PM   #4
Rewards Points: 596
Generally, single phase capacitor-start motors cannot be speed controlled. It'd be ok, but only for a narrow range of speeds. Once the speed reached the start winding switchover, speed control would be impossible.
Speed control based on reducing voltage would cause enough of a current increase to burn up the motor fairly quickly.
John Valdes (12-31-2011)
Old 12-30-2011, 09:47 PM   #5
Usually better to use a vfd with a single phase input and a 3 phase output. 3 phase motors are cheaper anyway
joethemechanic is offline   Reply With Quote
Old 12-30-2011, 09:55 PM   #6
Netree's Avatar
Never a motor gone bad on the variac. I must be full of luck!
Old 12-30-2011, 09:57 PM   #7
Thanks guys for the quick feedback! I wasn't sure because I have never been asked to slow a single phase motor down. What I have is a farmer with an auger feeding corn into a roller mill and its feeding it faster than the mill can grind it causing him to have to turn the auger on and off several times per batch which is wearing the starter out. Both are run by 5hp single phase motors and have the same rpm. I need to slow the auger down enough to feed continuous. Maybe change to a smaller pulley?
Old 12-30-2011, 10:35 PM   #8
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
Smaller pulley without question is the smart money.
The Following 2 Users Say Thank You to nolabama For This Useful Post:
John Valdes (12-31-2011), micromind (12-30-2011)
Old 12-30-2011, 11:20 PM   #9
Netree's Avatar
And less money.
Old 12-30-2011, 11:23 PM   #10
Yeah, if a single speed works for him, that would be the cheapest and best way out
Old 12-31-2011, 12:13 PM   #11
Rewards Points: 1,014
You could slow this down mechanically as stated by the others.
If it is direct drive, the introduction of a gear box could be beneficial. This will be much appreciated by the motor.
There is most likely a gear box in place already. This type of load would be bit much for a motor alone and might be way to fast. (exceptions do exist). I have seen it done. But a geared output is the norm.
Old 12-31-2011, 03:12 PM   #12
Thanks for all the help guys! I think we have the solution!
single phase motor / 3 phase starter electric mike PLCs, VFDs, Motors and Controls 15 12-28-2011 06:01 PM
Single & Three Phase Motor Loads on Three Phase Circuit josefbartos NEC Code Forum 4 09-05-2010 01:31 PM
Motor Speed Control Royston PLCs, VFDs, Motors and Controls 7 08-02-2009 01:31 PM
can a 200 mA speed control motor overload? theripley General Electrical Discussion 1 01-09-2009 10:45 AM
Speed Control Switch for Motor Absolutetruthz General Electrical Discussion 10 05-31-2008 09:29 AM
