Old 08-03-2009, 02:22 AM   #1
Default Testing resistance with a load
What would be an acceptable way to get an accurate reading for resistance with voltage applied? Tested from a 208 v motor.
And would readings from the capacitor also be possible?
Thanks.
EROD is offline   Reply With Quote
Old 08-03-2009, 08:13 AM   #2
drsparky's Avatar
Use ohms law.
Old 08-03-2009, 10:05 AM   #3
I know what the stated resistance is.
I want to test the resistance on the operating motor. I want to see if there is a change in impedance.
This may help. I work on large Printing presses. Certain components are difficult at best to get to.
Old 08-03-2009, 10:26 AM   #4
Zog
Zog's Avatar
Thanks.
Resistance of what? The insulation? The windings? Something else?
Zog is online now   Reply With Quote
Old 08-03-2009, 10:28 AM   #5
drsparky's Avatar
Check voltage while the motor is running, preferably with a RMS voltmeter, monitor amplitude at the same time. Divide voltage by amplitude. You now will have resistance while the motor is running.
Ohms law R=E/I
Generator Load Testing..... Hitch123 General Electrical Discussion 52 02-23-2010 06:45 AM
high resistance? 3tigerz Services and Service Equipment 8 04-18-2009 12:52 PM
high resistance? 3tigerz Site Help and Suggestions 3 04-09-2009 03:34 PM
Load Bank Generator Testing vs. Using Building Load to test generators. MR MAB Other Codes and Standards 15 03-16-2009 06:37 PM
Ohms(resistance) Testing wallace7777 Services and Service Equipment 19 11-23-2008 02:54 PM
