Originally Posted by MDShunk
I've never seen one, but apparently they exist. If a customer starts to need too many that size, it's time to give 3-phase supply some serious consideration.
That true normally I will recomend that they should go with triphase supply in first place if the POCO willing to bring the line to the customer location as far you know the cost of overhead line runs.
If they are close to it then it is will be not too bad but really IMO the POCO should expand more on triphase supply like what we did in Europe.
But somecase I can understand the distance of the POCO line if they were singlephase and the nearest triphase supply is more like 10 or more miles away then the cost will be way out of portion unless have few customer to sign up for triphase supply then it will justify it.
Merci.
Marc
