20 amp circuit for residential bathrooms - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 08-19-2011, 09:19 PM   #21
dronai's Avatar
Rewards Points: 3,337
Originally Posted by Peter D View Post
Generally speaking, any house built before that code change will likely have all the bathroom and outdoor receptacles on one 15 amp circuit, protected by a GFCI breaker or receptacle near the panel, or in the garage if you're in a "no basements" area.
Peter, I'm getting MS Paint lessons here !!! I already highjacked the thread ! Sorry Chris. 480sparky is the master of computer/NEC skills
We used to wire all new houses on 15A circuits, for the general convenience outlets. Then with the hairdryers on, along with everything else on, the breakers were always tripping. Then the new code into effect requiring a dedicated 20A circuit NEC 210.11(C) (3)
Old 08-19-2011, 09:45 PM   #22
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I did a quick bathroom today removed a double gang with a sw/receptacle and a single w/ a combo stack single pole. The stack was fed from a seperate 20 amp dedicated ckt. I installed one four gang box and used the #12 ckt for the GFI even though it shares a ex fan and heat lamp. Is this a legitimate conversion since that #12 wire feeds only that bathroom?
Old 08-19-2011, 10:12 PM   #23
dronai's Avatar
Exception: Where the 20A circuit supplies a single bathroom, outlets for other equipment within the same bathroom, shall be permitted to be supplied in accordance with 219.23(A) (1) and (A) (2)
Exception: 219.23 (A) The small appliance branch circuits, laundry branch circuits, and bathroom branch circuits required in a dwelling, shall supply only receptacle outlets.
Old 08-21-2011, 08:53 PM   #24
Default may the force be with you
Originally Posted by Chris1971 View Post
In what code cycle did the requirement for 20 amp circuit for bathroom receptacles take place? Did a service call in a town home built in 1991 and the receptacles had #14 to the receptacles.
Who ever wired the house missed the mark. A blow dryer "might" hold on a 15amp circuit, but the 2008 NEC only allows you to wire only receptacles in the same bath on a 20amp, that doent mean any lights or fans on that same 20 amp circuit. The northern California inspectors look at that very closely......
PureElectric is offline   Reply With Quote
Old 08-21-2011, 08:59 PM   #25
I own stock in FotoMat!
Rewards Points: 6,520
How do you expect someone back in 1991 to wire a bathroom to 2008 Codes?
Old 08-24-2011, 05:14 PM   #26
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
When I was coming up the popular thing to do was do all the exterior, bathroom, and basement receptacles that needed to be GFCI protected to be line/ load from the GFCI receptacle in an attached garage, closest to the MB panel. Talk about cheap, cheap, cheap. Knowing some of the older codes definitely gives you an advantage when troubleshooting I have found.
Replies based on NEC 2014
Old 08-24-2011, 07:34 PM   #27
Aegis's Avatar
Rewards Points: 1,646
Originally Posted by dronai
Better, but the OL's are too small to make them right
If you ever want to upgrade try Adobe Illustrator
Aegis is offline   Reply With Quote
6 Drops per 15 A circuit/8 Drops per 20 A circuit. Whats your opinion? romexrocket NEC Code Forum 32 06-11-2010 07:38 AM
Code Cycle - 20A GFCI required for bathrooms rexowner NEC Code Forum 13 05-20-2009 12:01 PM
lv in residential te12co2w Other Codes and Standards 4 02-04-2009 04:03 PM
lv in residential te12co2w Structured Wiring 3 02-04-2009 10:43 AM
