Old 09-03-2009, 10:21 AM   #1
Default aluminum to copper wire splicing
Is anyone working with aluminum romex cable inside homes.
If so, what are you currently using, for your wire splices.
Please provide details in how you go about making splices and connections, to switches and receptacles.
THANKS
partimer31 is offline   Reply With Quote
Old 09-03-2009, 11:11 AM   #2
I just finished a full remodel that had alot of aluminum wire. You have two options. Buy devices rated for al. or make pigtails with approved wirenut ($5.00 for two) In those house, I did both. I found devices rated for fairly cheap, and used about 30 of those wirenuts total. (some places I had to make joints)
Old 09-03-2009, 12:17 PM   #3
B4T Scotchkote installer
Black4Truck's Avatar
I just finished a pig tail job that was partially done by a hack
He cut the wires short and luckily I decided to use Ideal Purples for splicing.
If I had gone with just the devices, the wires would of been a nightmare to get around the terminals
Purples are only rated for AL/CU connections
According to manufacture not allowed for AL/AL, but I used them for it because better than a standard wire nut
Black4Truck is offline   Reply With Quote
Old 09-03-2009, 01:38 PM   #4
mcclary's electrical and black4truck
Thanks for your recent post.
I have a some follow up questions, for the two of you.
Did you both used the purple Idea 65 Twist-On?
And was this your your first job, involving aluminum romex cable?
THANKS
Old 09-03-2009, 01:46 PM   #5
child please.....
NolaTigaBait's Avatar
Yeah, I also use the purple ideal wirenuts. I've done several. Those things are way over-priced.
Old 09-03-2009, 01:47 PM   #6
Master RAT!!!
Shado's Avatar
When doing this upgrade, do you disturb any of the existing splices? Such as neutrals, etc.., what then?
- Dave ........
"Beware of the Rat....he has no Master...he works how & where he wants...."
Shado is offline   Reply With Quote
Old 09-03-2009, 02:00 PM   #7
I don't understand your thinking. How can something that is "not allowed" be a better option, in any circumstance? When the fire marshall finishes his investigation he will say you used the wrong wire nuts.
Wood alcohol: Cannot be made non-poisonous.
Of all the lessons dad could have left out...
busymnky is offline   Reply With Quote
Old 09-03-2009, 03:30 PM   #8
I've done several remodels that had aluminum. Don't worry about "disturbing" anything. As long as you've got worenuts approved, you're fine. Just be really careful when stripping. DO NOT knick the condutor with strippers. Al. is much more delicate than copper. If it's knicked, when you put on wirenut it wil break and you may not notice it. of course, don't disturb anything you don't have to.
Old 09-03-2009, 03:36 PM   #9
I use regular wire nuts in most cases. I personally don't believe that the wirenuts are the issue. If they were, why don't all the millions of splices fail?
I pull apart AL on a regular basis and generally don't see any issues if it was installed properly.
The issues I see are where someone has changed out the switches/receps with copper devices and where the wire was ringed during stripping and snapped off after it was bent back into the box.
If it's a specific whole house pigtail job, I will reluctantly submit to the scam/hype/liabilty scare and use purple nuts.
Old 09-03-2009, 04:59 PM   #10
I'm with you!,,,,it's just a wirenut with no-ox inside, however,I think it's got a less aggressive thread pitch, to prevent stripping the soft al. When we're talking about liability, and not to mention the inspectors around here look closely, I ALWAYS use the right wire nut.
Old 09-03-2009, 06:00 PM   #11
What would you do if it was your house??
They don't make a wire nut that is UL approved for AL/AL splices
My choices are either leave a 40 year old wire nut on the neutrals in a switch or use a Purple
I don't think that adding a copper element to an AL splice has any mystical powers to make it "approved"
I am also adding arc fault breakers to all circuits mandated in the NEC
Old 09-03-2009, 06:53 PM   #12
For those that don't like the Ideal purples.
http://www.kinginnovation.com/produc...cts/alumiconn/
They call for a torque screwdriver, but do list an alternate method.
Jim Port is offline   Reply With Quote
Old 09-03-2009, 08:27 PM   #13
I generally make a big pile of aluminum wire on the floor as I'm installing new copper romex. That's how I splice aluminum.
Old 09-04-2009, 09:40 AM   #14
To you guys out there working with aluminum romex, thank you , for submitting your posts.
Here is a link you may want to take a look. To those who do look at it, I welcome all feed back, positive
and negative.
http://www.inspect-ny.com/aluminum/alreduce.pdf
Old 09-07-2009, 08:48 PM   #15
Ok to use regular nuts for Al splicing in the basis that not all the millions of splices out in the field have failed???
Come on... isn't this forum supposed to be for 'professionals'??
mikheil is offline   Reply With Quote
Old 09-07-2009, 08:58 PM   #16
delected due to computer operator error
Old 09-07-2009, 08:59 PM   #17
I like this guy. I like where he's going.
Old 09-08-2009, 07:30 AM   #18
I thought it was for professionals, but there's a few hacks on here too not mentioning any names
Old 09-08-2009, 08:19 AM   #19
We always name names.. no fun otherwise
Old 09-08-2009, 08:32 AM   #20
Not Peter D
Bob Badger's Avatar
It strikes me that there must be a reason no one is selling overpriced AL to AL wirenuts. If they could make a safe one I am sure they would be available.
Just something to think about.
Copper vs. Aluminum wiring at Switch panel... Jara Jones NEC Code Forum 1 10-07-2008 02:45 PM
aluminum wire repair crk1a General Electrical Discussion 8 08-19-2008 09:18 PM
10G copper wire $100 sl3martn Electrician Swap 0 08-18-2008 08:37 PM
aluminum wire repair crk1a Other Codes and Standards 1 08-18-2008 04:34 PM
splicing/junction in panelboard gcleary47 NEC Code Forum 4 06-10-2008 02:51 PM
