Originally Posted by electricalwiz
Here is some detailed installation options under the assumption that that what you are working with is low voltage:
- Come down inside the wall with the cable to a single gang old-work low-voltage work box. Install a plastic cover w/1/2” KO. Use a ½” 2 screw connector on the cover and one on the 8161 CB.
- Come down inside the wall with the cable to a single gang old-work low-voltage work box. Install a plastic cover w/1/2” KO. Use a 3/8” LFNC whip to the 8161 CB.
The combinations are almost unlimited and it just depends on costs, matching what is there already and what kind of customer it is. For example if it was a bank you might want to use high end materials.
