Basement Layout - How does it look? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree99Likes
Old 03-18-2017, 12:36 PM   #1
NDC
NDC's Avatar
Rewards Points: 532
Default Basement Layout - How does it look?
There are 2 pot lights directly in front of the wall mount TV that I may delete. My client says the room will get converted into a party room frequently though.
There is an exit to a walk out patio with french doors.
There are two entrances to the basement from the main floor and they are already wired to two separate lights at the basement landing. I would Ideally like to have one light operated by either switch. Any suggestions?
Be as critical as you like! I'm still very new to designing layouts.
Edit: I forgot a jumper to a pot above the toilet.
Old 03-18-2017, 12:49 PM   #2
Rewards Points: 9,146
Nice. No switches at the patio door (indoor/outdoor lighting)? Do they want more exterior receptacles since you have access?
NDC likes this.
Old 03-18-2017, 12:55 PM   #3
Click Here
Rewards Points: 1,400
I still think the lighting in the main room is crazy.
2 rows of 5 would be plenty of light for everything other than nano-surgery.
Old 03-18-2017, 12:56 PM   #4
NDC
NDC's Avatar
Rewards Points: 532
Yeah there is already a switch to an exterior light. I guess the builder did it. Should I add a 3 way at the patio door for the rec room lights? Is that code?
Old 03-18-2017, 01:00 PM   #5
NDC
NDC's Avatar
Rewards Points: 532
That room is 17 x 38. Three rows on a dimmer I think is less risky than not having enough light don't you think?
Old 03-18-2017, 01:02 PM   #6
Click Here
Or maybe bump up to 6" for a few bucks more.
BTW, I am not saying to listen to me, it's just that it seems like a lot of lights.
NDC likes this.
Old 03-18-2017, 01:03 PM   #7
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,072
It's wicked bright yo.
Majewski is online now   Reply With Quote
Old 03-18-2017, 01:06 PM   #8
NDC
NDC's Avatar
Rewards Points: 532
Added the panel picture which is full. I may need to price out a sub panel too but I know anyone else quoting will just add mini breakers to make room.
Majewski likes this.
Old 03-18-2017, 01:14 PM   #9
Majewski's Avatar
You have to stress the NEED for it vs the lower bidder....Or offer some sort of grouping discount, yeah?
NDC likes this.
Old 03-18-2017, 01:20 PM   #10
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,854
Fewer pots.
1 receptacle in hall is plenty.
1 receptacle each side of expected bed location. Not code but I still it consider
a minimum.
P&L
splatz, Majewski and NDC like this.
Old 03-18-2017, 01:23 PM   #11
Safety Pin Member
I avoid putting more than 3 switches in a single box. Too hard to remember
what does what. Like to break them into 2 2gangs, or whatever makes sense.
P&L
Bird dog, Majewski and NDC like this.
Old 03-18-2017, 01:24 PM   #12
NDC
NDC's Avatar
Rewards Points: 532
Some really good input here. Thanks fellas
Majewski and PlugsAndLights like this.
Old 03-18-2017, 01:36 PM   #13
NDC
NDC's Avatar
Rewards Points: 532
P&L
For the little kitchenette I will likely separate the two switch banks as suggested. One two for pots in open space and two for kitchenette (under cabinet/pots)
Old 03-18-2017, 01:39 PM   #14
MikeFL's Avatar
Rewards Points: 1,132
Send a message via Skype™ to MikeFL
Depending on the elevation of the building's sewer outlet you may need a macerator pump for the new bathroom in the basement.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
Old 03-18-2017, 01:41 PM   #15
Absolutely. Imagine if you put this plan on your tablet and combined it with photos of previous jobs and catalog cuts of the products you like to use. You're miles ahead of Bare Bones Electric and his quote written on a piece of cardboard with a felt pen. You can sit down with the customer and discuss priorities and budget professionally.
This is something I'm working on myself since, previously, I had GC's and interior designers do it for me.
Ignore the guys who say you can do it with ten fixtures. Sure you can but 21 will give you very nice uniformity. If there are budget concerns, you can reduce your fixture count but your customer can expect dark spots. If you recommend ten and you have dark spots then you're in a chit load of trouble.
You're better off presenting the gold plan and trimming the fat to meet budget. If you start with bronze, you might turn it into silver but gold will be impossible.
Think like a plumber. A plumber will sell a jetted tub with all the bells and whistles. If an electrician went into plumbing, he would sell a beat up tub from the clearance section at HD because "that's all they need".
The_Modifier, splatz and NDC like this.
Old 03-18-2017, 01:42 PM   #16
I think 3 ways on the stairways and from the main switches to the French doors would be a great addition while you're still able to easily get them done. Maybe even a 4 way for the stairways, one at the bottom and one at each landing upstairs. I assume the jumper you are missing for the toilet can is wired in with the exhaust fan? If not I think that would also be a good idea. Also having that many cans in a room I would suggest zoning them so you don't have everything on at once. Will you be using led trims on these? Seems like a lot of lighting on one switch if not, especially if dimmers will be used.
NDC likes this.
BlueOval5272 is offline   Reply With Quote
Old 03-18-2017, 01:50 PM   #17
You have laid this out almost exactly how I would do it. I'm with P & L, though. I rarely install anything more than three gangs.
Put a damn alarm on that fridge if you have to arc fault it .
NDC likes this.
Old 03-18-2017, 01:56 PM   #18
NDC
NDC's Avatar
Rewards Points: 532
Hi the entire basement lighting will be on one circuit. The 37 pots are slim led panels 12W
The Following User Says Thank You to NDC For This Useful Post:
Soilentblue9 (03-21-2017)
Old 03-18-2017, 01:57 PM   #19
NDC
NDC's Avatar
Rewards Points: 532
There is a mini fridge that I will have to afci but it's just for drinks. The larger fridge near the south wall will be dedicated and no afci.
99cents likes this.
Old 03-18-2017, 02:23 PM   #20
MikeFL's Avatar
8 outlets at the tv and prewire for badass sound system. Maybe outlets and sound high up on the wall behind the tv to hide the rat's nest.
You don't show power in the utility room for washer & dryer and an iron.
(239) 848-6675
Changing the circuit layout 746 Watts Residential Electrical Forum 47 03-14-2017 06:35 PM
Roughing-in a basement Arcflasher Residential Electrical Forum 22 11-13-2016 08:32 AM
UF in basement Spark Master Residential Electrical Forum 38 09-22-2016 12:25 PM
Wiring Demoed Basement MooseOnaHill General Electrical Discussion 1 03-05-2016 02:22 PM
Pot light Layout darren79 Lighting Design 32 02-27-2016 04:24 PM
