Old 05-05-2012, 10:36 AM   #1
Default Copper Theft
I was called about repairing some electrical damage due to thieves. What I found was very surprising. Has anyone come across wires being cut that close to the back of the panel? I need some ideas on repairing this. I have to change out the panel to an all in one due to the utility requirements but I don't know how to safely make those branch circuits longer. This is in a two story condo with no crawl space. My first thought was to cut an access hole in the kitchen wall right behind the panel and use those wire splice kits that don't need to be in a j-box, but they will not work with #8 wire. What do you guys think?
Prism is offline   Reply With Quote
Old 05-05-2012, 10:42 AM   #2
If the cables come from the top side of the wall, I would do what 220/221 does and make a hole in the top of the new panel and pull the extra slack inside of the wall. Yeah, it's a code violation to do it that way but it doesn't seem to stop him.
Old 05-05-2012, 10:54 AM   #3
1,000,000th Poster
Big John's Avatar
I wonder if they kept stealing even after it blew up in their face?
Getting desperate, huh?
-John
Big John is online now   Reply With Quote
Old 05-05-2012, 10:56 AM   #4
Chief Electron Relocator
-John
When you're high on meth, chit like that doesn't phase you.
Old 05-05-2012, 11:07 AM   #5
1,000,000th Poster
Big John's Avatar
I'm trying like hell to turn this into an electrical pun.
-John
Old 05-07-2012, 09:21 AM   #6
They don't make a 8 awg lug, and heat shrink? (can this be exposed?)
Svtlightning207 is offline   Reply With Quote
Old 05-07-2012, 09:41 AM   #7
Thats a good thought but any splicing has to be in an enclosure and there is only about a 1/4 inch of wire coming in the back of the panel. Hmmm....
Old 05-07-2012, 10:14 AM   #8
This amp goes to 11
How about maybe pulling the panel down and see what you have. Its not like your gonna have to fight all the wires out of that panel!! Plus you've got to replace the feed too, so I'd say pull the panel and see what you have. You might be able to slide the panel up also and make up some length, then rework the feeds into the bottom of the panel instead of the side. Good luck
TimChaput69 is offline   Reply With Quote
Old 05-07-2012, 10:26 AM   #9
ET rocks
3xdad's Avatar
They ripped off a bunch of 12 & 14 aluminum?
Block wall doesn't make things easier too.
Have power co. shut it down, and just demo all that mess. Use existing secondary pipe location to an all in one. Go inside house and open up that wall and inside flush a giant j-box. Purple wire nut to copper then nipple into back of service.
Just a thought. i know it's easier said than done.
i would sub it to 220 and make a percentage.
"Starbucks makes you vote funny" ..macmikeman
"I'm gonna try something I call a compliment sandwich..." ..Big John
"i do love me some gutter" ..Eric
3xdad is offline   Reply With Quote
Old 05-07-2012, 07:19 PM   #10
magneticpersona's Avatar
thats an easy one, just take the meter out, replace cut wires with new service wires from the panel back to the meter base
magneticpersona is offline   Reply With Quote
Old 05-07-2012, 07:20 PM   #11
ET rocks
3xdad's Avatar
What about the branch circuits mag?
The Following User Says Thank You to 3xdad For This Useful Post:
swissmiss177 (05-31-2012)
Old 05-08-2012, 12:28 AM   #12
Wow the theifs really clean that one out and that was a nice split buss setup.
Let Mr 220/221 do this part due he have good magic on this one to get it working well.
Merci,
Marc
Old 05-08-2012, 11:31 AM   #13
Wow, they did a number on that one. We see a lot of theft in Montana but that's gonna be a challenge. Good luck!
TylerElectric is offline   Reply With Quote
Old 05-31-2012, 08:37 PM   #14
Install a new panel higher on the wall.
mikeykcl is offline   Reply With Quote
Old 05-31-2012, 09:29 PM   #15
B4T
ET Road Warrior
B4T's Avatar
So when was the last time you were high on meth..
B4T is online now   Reply With Quote
Old 05-31-2012, 11:12 PM   #16
When was the last time you were a doofus?
Old 05-31-2012, 11:19 PM   #17
Heavily Armed Member
HARRY304E's Avatar
When was the last time you were a "pimple popping punk".?..
Old 05-31-2012, 11:19 PM   #18
still in business
sbrn33's Avatar
I could be wrong but I don't think those deals are rated for burial in drywall
Stop trying to think logically, it won't help you here. Just do as we say and everything will be alright.
Old 05-31-2012, 11:20 PM   #19
When was the last time you were a phony conservative?
Old 05-31-2012, 11:21 PM   #20
HARRY304E's Avatar
At the same time as you Doctor....
Wow.. Huge copper theft. kevmanTA Off Topic 4 01-16-2012 10:23 PM
More on copper theft Chris Kennedy General Electrical Discussion 83 06-13-2011 09:24 PM
copper theft Mr Rewire General Electrical Discussion 13 05-03-2011 05:16 AM
copper theft at the next level nolabama Off Topic 2 04-09-2011 08:39 AM
Felony Copper Theft shepman General Electrical Discussion 68 05-31-2010 01:52 PM
