Cutler Hammer BR burned - Electrician Talk - Professional Electrical Contractors Forum
Like Tree61Likes
Old 03-24-2017, 08:18 AM   #1
Rewards Points: 588
Default Cutler Hammer BR burned
This always seems to happen on cutler hammer BR panels usually when a heat pump and air handler breaker on in the top slots. Is there something wrong with the BR breakers that won't let them trip?
JBrzoz00 is offline   Reply With Quote
Old 03-24-2017, 08:27 AM   #2
RePhase277's Avatar
Rewards Points: 4,638
It isn't unique to BR panels I assure you.
I see this where a heavy load is connected to a breaker that shares bus tabs with another larger breaker. The heat build up is probably the culprit. A breaker larger than 40 amps should probably be alone on the tabs, no breaker across from it. This would help keep it cool.
The Following 2 Users Say Thank You to RePhase277 For This Useful Post:
Bird dog (04-06-2017), Majewski (05-31-2017)
Old 03-24-2017, 12:07 PM   #3
Rewards Points: 4,452
Improper torque is most likely the causation of that . And,,,,,,,, usually the printed proper torque the engineer's decide on is the improper level. Usually dangerously loose if following the printed specs...
Majewski likes this.
It would have been impossible for us to develop our plan for the world if we had been subject to the bright lights of publicity during those years. David Rockefeller
Old 04-06-2017, 12:16 AM   #4
Rewards Points: 325
Personally, I think it's a design flaw. Have you ever seen a QO burn like that? I haven't.
in Lawrence, KS
bartstop is offline   Reply With Quote
Old 04-06-2017, 06:57 AM   #5
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,892
I've seen QOs burn but, it's rare.
I has a bit of a cronic problem like that.
As an experiment, I installed a 70 amp breaker. It looks like it shares the same frame and guts as a 100 amp. I haven't had that burning problem on that site again.
Btw, it was a tankless water heater installation.
Old 04-06-2017, 07:46 AM   #6
Deplorable-Electrician
Rewards Points: 2,406
I can see putting an air handler breaker and heat pump breaker above / below each other but never on the same tabs.
To me that is just poor workmanship of an inexperienced installer..
lighterup and telsa like this.
Old 04-06-2017, 08:29 AM   #7
still in business
sbrn33's Avatar
Rewards Points: 3,492
Improper torque had nothing to do with that. If anything it was a faulty breaker.
but this is the economically depressed South and we're just a bunch of barefooted cousin humpers.
Old 04-06-2017, 08:31 AM   #8
still in business
sbrn33's Avatar
I have seen more QO's burnt than any other brand by far. That is usually because they pop off the buss easier than I can pop open a beer.
Old 04-06-2017, 09:34 AM   #9
Rewards Points: 10,008
I haven't seen any QO burnouts but I did have a run of duds that didn't work at all.
Old 04-06-2017, 08:55 PM   #10
Cow
Rewards Points: 2,480
It's an aluminum bussed panel, I see this regularly in aluminum bussed panels....just had a call two weekends ago for the same thing but it was a dryer breaker in an aluminum bussed Siemens panel.
Twins and quads to move the breakers off the bad stab is the usual fix. If it's really bad or they are out of space...panel change!
Old 04-06-2017, 09:03 PM   #11
Rewards Points: 15,840
Mac loves sarcasm.
Old 04-07-2017, 09:02 PM   #12
Rewards Points: 172
Another BR typical. Get a panel with a copper bus. QO is one of the best. I think BR offers one too.
John M. is offline   Reply With Quote
Old 04-07-2017, 09:12 PM   #13
Some guys don't think copper buss panels are better.
Old 04-07-2017, 10:54 PM   #14
Cow
Hackwork disagrees with me everytime I say the same thing....
I've seen probably no less than 15 aluminum bussed panels with burned stabs, but only one copper bussed panel so far.
Is it because the ratio of aluminum to copper bussed panels in this area is 15-1? Or are aluminum bussed panels just turds?? I'm leaning towards they are turds....
Old 04-07-2017, 10:58 PM   #15
I've NEVER seen a residential panel that was copper.
15-1 would seem LOW.
shocksystems likes this.
Old 04-07-2017, 10:59 PM   #16
I lean towards the latter myself. I like copper over aluminum for any purpose.
Old 04-08-2017, 12:54 AM   #17
still in business
sbrn33's Avatar
So you have never seen a QO, Siemens or even a FPE? Pushmatics were copper. Pretty sure Almost every single resi panel around here is.
Did your internet search not quite work that well?
Old 04-08-2017, 02:58 AM   #18
Fish On!
lighterup's Avatar
Rewards Points: 2,157
I used to see them all the time around here , but just recently I
had a customer specifically request I do not use aluminum buss
panel , so it then became obvious to me that the single phase
residential breaker panels (with copper busses) are getting
more challenging to find.
I chose square D QO because it proclaimed "copper buss"...
When I got to the job and opened up the box , removed the
door ...it looks like an aluminum buss...it's not copper colored...
it says copper but it appears to be aluminum. What the heck?
Old 04-08-2017, 03:30 AM   #19
I made the same mistake before. The buss is tinned copper. (coating). Scratch the bus with a sharp edge and the copper is down there below the shiny parts.... Most all the so called ''aluminum buss bars'' you hear about in this thread are really copper busbars tinned.
The Following 2 Users Say Thank You to macmikeman For This Useful Post:
lighterup (04-08-2017), shocksystems (04-09-2017)
Old 04-08-2017, 03:33 AM   #20
drspec's Avatar
Rewards Points: 656
Siemens PL series is copper buss
sbrn33 and MechanicalDVR like this.
Square d qo and cutler hammer bus parts rrolleston General Electrical Discussion 5 10-04-2016 01:21 PM
Cutler Hammer CH Breaker A Little Short General Electrical Discussion 2 08-17-2016 12:41 AM
what is the best sized hammer for residential work? hatsgoods Tools, Equipment and New Products 59 07-29-2016 05:57 PM
Cutler Hammer CH breakers JohnJ0906 Vintage Electrical 4 04-15-2016 12:22 AM
Cutler hammer plug on neutrals Arrow3030 General Electrical Discussion 31 02-09-2016 09:02 PM
