Drilling through I beams - Electrician Talk - Professional Electrical Contractors Forum
Old 07-13-2012, 04:29 PM   #1
Rewards Points: 154
Default Drilling through I beams
There seems to be a debate amongst some of the trades in regards to drilling through beams. So how far along the beam and how far apart d o you drill holes?
FCR1988 is offline   Reply With Quote
Old 07-13-2012, 04:34 PM   #2
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
You had better get a structural engineer involved before you make ANY holes.
Drilling a hole in any engineered product whether it be wood or steel could end up taking a big chunk of your profit or cause an insurance claim.
Pete
The Following 2 Users Say Thank You to Pete m. For This Useful Post:
360max (07-13-2012), Roger. (07-13-2012)
Old 07-13-2012, 04:34 PM   #3
Rewards Points: 278
I have drilled I beams but not without an engineers okay- you drill in the wrong place you are in deep doo-doo
Old 07-13-2012, 04:40 PM   #4
Data Tech/Apprentice.
Rewards Points: 22
If I have to do it, I go as small as I can.
Old 07-13-2012, 04:43 PM   #5
Rewards Points: 154
Damn, yea we're in apartments and theres no other way to run wire. But no one is any help on the jobsite.
Old 07-13-2012, 04:44 PM   #6
Rewards Points: 278
I have drilled 2 " holes thru them. Theoretically, the middle part from top to bottom, does not carry any load. I bet if you stay in the first 1/3 of the length at either end you would be okay. It is probably similar to floor joist.
The Following 3 Users Say Thank You to Dennis Alwon For This Useful Post:
19kilosparky984 (07-13-2012), chewy (07-13-2012), nolabama (07-13-2012)
Old 07-13-2012, 04:45 PM   #7
Rewards Points: 278
I have to go up and down around the steel thru the wall.
Old 07-13-2012, 04:53 PM   #8
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
Wood or steel?
The Following User Says Thank You to electricmanscott For This Useful Post:
hardworkingstiff (07-13-2012)
Old 07-13-2012, 05:27 PM   #9
angryceltic's Avatar
Rewards Points: 252
Have the foreman submit an rfi
angryceltic is offline   Reply With Quote
The Following User Says Thank You to angryceltic For This Useful Post:
MechanicalDVR (07-19-2012)
Old 07-13-2012, 05:47 PM   #10
360max's Avatar
Rewards Points: 656
....use beam clamps like everyone else, that's the way its done.
360max is online now   Reply With Quote
The Following 2 Users Say Thank You to 360max For This Useful Post:
Salvatoreg02 (07-14-2012)
Old 07-13-2012, 05:53 PM   #11
Rewards Points: 278
How does a beam clamp help if you cannot pass over or under and need to get to the other side?
The Following 2 Users Say Thank You to Dennis Alwon For This Useful Post:
electricmanscott (07-14-2012), hardworkingstiff (07-13-2012)
Old 07-13-2012, 06:08 PM   #12
360max's Avatar
Rewards Points: 656
...if there is no other option, the structural engineer will tell you, IN WRITING, where do drill and how far apart.
Old 07-13-2012, 06:12 PM   #13
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Here is a link with all kinds of info.. look under "installation guide".. http://www.gp.com/build/product.aspx?pid=1390
Old 07-13-2012, 07:32 PM   #14
Rewards Points: 594
Depends what kind of ibeam. Im picturing a tgi
jimmy21 is offline   Reply With Quote
Old 07-13-2012, 07:44 PM   #15
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
Hougan bit - mag drill - drill away
The Following User Says Thank You to nolabama For This Useful Post:
socalelect (07-14-2012)
Old 07-13-2012, 07:59 PM   #16
All you have to do is grab one of the little booklets that is attached to just about every beam.
In there it has exact locations you can drill. Pretty much exactly what Dennis posted.
By the time that "structural engineer" gets back to you the GC will have found a competent EC to replace you with.
19kilosparky984 is offline   Reply With Quote
Old 07-13-2012, 08:15 PM   #17
Rewards Points: 22
In leiu of a mag drill Ive just used plenty of cutting oil and a 32mm holesaw.
Alternatively Ive bought the iron workers a box of beers and they cut holes Ive marked with a plasma cutter.
Old 07-13-2012, 08:16 PM   #18
Licensed Journeyman
nolabama's Avatar
I have used hole saws also - hougan bits are waaaay better
Old 07-13-2012, 08:22 PM   #19
Rewards Points: 22
They wouldnt work with just a handheld power drill would they?
Old 07-14-2012, 01:23 AM   #20
360max's Avatar
Rewards Points: 656
I work primarily industrial, so there are no booklets attached to the beams, and the beams are massive pieces of steel. As for the 'competent EC' comment, if I drilled a hole thru a steel beam to run anything without prior written approval, I'd be down the road before the bit cooled!
Drilling through foundation Zparme General Electrical Discussion 30 06-11-2011 12:36 AM
Drilling tile Chris Kennedy Off Topic (Non Trade) 12 01-23-2011 04:25 AM
Attaching 4 sq. boxes to I-beams subelect General Electrical Discussion 29 01-06-2011 01:55 PM
drilling holes den Tools, Equipment and New Products 20 02-21-2010 11:03 PM
panel drilling spec grade General Electrical Discussion 15 10-18-2009 11:17 PM
