Old 11-09-2009, 09:44 PM   #21
Unlimited Lic.Electrician
william1978's Avatar
Originally Posted by rdr View Post
william1978 is online now   Reply With Quote
Old 11-09-2009, 11:19 PM   #22
sparks134's Avatar
Originally Posted by william1978 View Post
sparks134 is offline   Reply With Quote
Old 11-10-2009, 10:35 AM   #23
Ax grinder
raider1's Avatar
Originally Posted by nolabama View Post
thats because there isnt one
312.8
so you can, its just not good worksmanship!!!
312.8
Chris
Old 11-10-2009, 10:44 AM   #24
Licensed Journeyman
nolabama's Avatar
Originally Posted by raider1 View Post
312.8
312.8
Chris
I posted that you could not use a panel as a pull box. After reading 312.8 again I discovered that I was wrong.
Old 11-10-2009, 12:53 PM   #25
sparks134's Avatar
ok!!!
Old 11-10-2009, 01:46 PM   #26
Licensed RAT
robnj772's Avatar
Where has that ding dong been?
I hope it wasn't on Hotel St
"I don't worry about terrorism. I was married for two years. "
Sam Kinison
robnj772 is offline   Reply With Quote
Old 11-10-2009, 04:10 PM   #27
bored member
BuzzKill's Avatar
Negative, read further: "...unless adequate space for this purpose is provided....the conductors, splices and taps shall not fill the wiring space at any cross section to more than 75 percent of the cross sectional area..." (2005 NEC)
So a panel used as a pull box/jbox, you are in the clear.
oops, yep...got confused there, duhhh!
Old 11-10-2009, 04:21 PM   #28
Not Peter D
Bob Badger's Avatar
yes no always never sometimes
Bob Badger is online now   Reply With Quote
Old 11-10-2009, 04:39 PM   #29
bored member
BuzzKill's Avatar
seems that way at times: I've had bosses/inspectors try and flag me on that...
Old 11-11-2009, 12:17 AM   #30
Default pull box /junction box
At the construction site where I am working, yesterday I saw a 50 cal ammo box...the green ones that you can buy at army surplus used as a junction box. So is Tupperware the JB of the future?
Missouri Bound is offline   Reply With Quote
Old 11-11-2009, 01:57 PM   #31
Licensed Journeyman
nolabama's Avatar
I have had bosses say no to it.
Old 11-11-2009, 03:17 PM   #32
bored member
BuzzKill's Avatar
It's alljust cosmetics.
Old 11-14-2009, 03:00 PM   #33
Total blow hard.
Rudeboy's Avatar
What else are you going to do with an old FPE panel?
Old 11-14-2009, 03:47 PM   #34
cdnelectrician's Avatar
I've done it on panels that were set in old block walls. What else can you do in that situation? Had a cover made up out of #12 steel and painted it grey, threw it on and there ya go!
Old 11-15-2009, 02:50 PM   #35
Space Rat
Power Tech's Avatar
Originally Posted by sparks134 View Post
can a panel be used as a pullbox?
Yes I do, and have done it for 30 years, in 5 counties.
I use sheet metal from an old panel to cover the breaker dead front.
If the panel is recessed in the stucco I fish a few 3/4 flex into a J-box and run conduit to the new panel location.
After swing service, I pull the old mast, seal the roof, and do the change over.
Have never put one in but have seen panels piggybacked.
Power Tech is offline   Reply With Quote
Old 11-15-2009, 02:55 PM   #36
Space Rat
Power Tech's Avatar
Me too. I drove it down their throat and made them look like the fools they were.
Old 11-15-2009, 09:22 PM   #37
Total blow hard.
Rudeboy's Avatar
Nice, I've just slapped a couple of self-tappers on and called it done.
Old 11-15-2009, 09:35 PM   #38
Space Rat
Power Tech's Avatar
Yea, I go too far but, I open the cover and see the wire and ..... just couldn't leave it.
Truth will be found where men are free to seek it. Benjamin Franklin
Old 11-15-2009, 10:23 PM   #39
rdr
rdr's Avatar
Ok somebody straighten me out on this. I can see if you replace a service or some dummy cuts a wire too short or what have you maybe having a splice or a few splices in a panel but somebody fathom for me why you would have to use a panel as a pull box.
rdr is offline   Reply With Quote
Old 11-15-2009, 10:27 PM   #40
Space Rat
Power Tech's Avatar
A pull box does not have connections, this is a J-box there are connections in it.
Answer----All the breakers are in it, you remove the guts and make the connections.
Does a pull box need to be grounded? jayare813 General Electrical Discussion 31 11-11-2009 08:18 PM
Some steps to know about electrical control panel ricky001 General Electrical Discussion 4 08-22-2009 07:35 AM
Pull box subelect NEC Code Forum 15 05-02-2008 10:20 PM
Wooden Electrical Panel Speedy Petey Vintage Electrical 14 11-29-2007 07:54 PM
Lutron lighting system panel PLEASE HELP ! POSTED IN UK ELECTRICAL 50 hertz 60 kills ya General Electrical Discussion 0 11-03-2007 12:56 PM
