Flat roof and recessed
Is it possible to install any kind of recessed lighting in a ceiling/roof construction of (from bottom to top) ceiling/roof decking (2x8 T&G), 5/8" plywood, 4-1/2" rigid foam, 1/2" denseboard, roofing membrane. We are reroofing a completely flat roof.
The architectural style is exposed beams and exposed roof decking . There is no chance of lowering the ceiling, nor is it possible to raise the roof to provide space above the decking. The above mentioned "sandwich" is what we have to work with.
Hoping there would be some super-low housings (possibly low voltage or LED), or perhaps low housings that are allowed to stick into the rigid foam.
