05-03-2012, 04:52 PM
Genaerator Installation
Anyone do residential generator installs? If so, what do you use to move them into place? I'm thinking of renting a Toro Dingo. Looking for other options.
The Following User Says Thank You to Chris1971 For This Useful Post:
05-03-2012, 04:56 PM
I use a furniture dolly.
I lay two sheets of 5/8" plywood down, move the unit across to the end, then "leap frog" the plywood sheets.
This has worked even over rocky and rooty ground. On grass it's easy as pie.
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
05-03-2012, 04:59 PM
I've considered that. I have a slight incline and a longer distance to move it. About 200' from street.
05-03-2012, 05:00 PM
Ive only done one resi generator(well, i helped).
We just asked some workers to help us carry it to the pad.
I would think a couple guys could use pvc pipe as rollers.
I'm just hoping to not end up on Electricmanscotts signature line.
05-03-2012, 05:02 PM
The PVC option has been mentioned to me before. Looking at any options.
05-03-2012, 05:03 PM
+1 on pvc. You can move alot of stuff with pvc. Even heavier stuff on black iron pipe.
05-03-2012, 05:12 PM
"When a your only tool is a hammer, every problem looks like a nail"
Wow, that is a long way.
A small tilt trailer (4x6) and an ATV.
You can tow the ATV and then use it to move the trailer.
You didn't mention how much money you wanted to spend.
05-03-2012, 05:15 PM
Originally Posted by jrannis
I saw that online this morning. They have a motorized version for $7k.
05-03-2012, 05:18 PM
ET Road Warrior
First off.. I install my air cooled generators on a 4X6 CCA frame.. it keeps it off the ground and makes the install much easier..
I bought one of these carts.. it has balloon tires and is easy to roll over grass..
When the generator gets delivered.. I put the cart next to the lift gate and slide it over..
I have (4) trailer jacks that I put plastic wood on the feet to make it more stable..
Slide a 3/4" gal. pipe through the lifting holes and place the (4) jacks onto the end of the gal pipes..
Jack up the generator.. remove the pallet..
I set up a winch in my van with (2) 2X8 planks that have angle iron bolted on the bottom..
Same as I winch the generator into the van.. I remove it the same way..
Push the cart next to the 4X6 frame.. put (2) 4X6 blocks on the frame and slide generator over..
I slide a pipe through the factory holes and a piece of rope that is a circle.. it allows me to pick up generator with one hand and slide out the block with the other..
This system works really well and I have used it to install all (10) generators I sold..
The Associated Press wants to stop using the term "Illegal Aliens".. they say it is demeaning.. .. instead they want us to use Undocumented Democrats... Jay Leno..
The Following 5 Users Say Thank You to B4T For This Useful Post:
05-03-2012, 05:22 PM
I would pay 4 high schoolers $25 apiece to pick it up and carry it where I wanted it.
05-03-2012, 05:27 PM
ET Road Warrior
More pics..
The Following 4 Users Say Thank You to B4T For This Useful Post:
05-03-2012, 05:56 PM
I have a dolly for my generators that one person can roll it around with ease. One dolly is for Generac and one is for GE/Briggs.
05-03-2012, 07:41 PM
Do you have a picture of the dolly?
05-04-2012, 07:37 PM
Can't Remember
Here's an ebay link:
http://www.ebay.com/itm/Generac-Air-...item5ae4e15f5b
The supply house I usually buy from has one they bring out on the delivery truck and help you put it in place for a small fee. Makes the whole logistic thing that much easier.
05-04-2012, 08:44 PM
Originally Posted by nrp3
Thanks. My supply house doesn't deliver the generators. We need to pick them up.
05-04-2012, 09:13 PM
Tesla was right
We made handles out of 1/2 in gas pipe, we set up one piece of pipe so we can fit it with 2 replacement lawn mower front tires so one person can drag it into place. I went to sears and looked at how they set up the lawn mower carts and copied the setup.
05-04-2012, 10:37 PM
#18
Bababoee
Two sticks of 1" rigid pipe and three muchachos...I just factor it into the install.. If i did a gen a month maybe i would buy something ...
Full time Bovine Scatologist.
05-05-2012, 07:02 PM
#19
Heavily Armed Member
Why not.?
05-09-2012, 07:55 AM
#20
Originally Posted by HARRY304E
Why not.?
They simply do not do it.
