Old 04-29-2012, 05:41 PM   #1
Default GFI outlet
Alright first off im new to this site obviously and still pretty new to the trade as an apprentice... so heres my question
My parents house was built mid 80s and had an outlet installed outside on the deck. A few months ago my dad and I replaced the outlet with a GFI. Ever since we replaced it the outlet keeps tripping. Im not really sure why it keeps doing it and after researching through google it said it could be one of the other outlets somewhere else in the house has gone bad.
so if you guys have any info. on this please help! thankyou in advance and i look forward to learning more from this site
BohsOs is offline   Reply With Quote
Old 04-29-2012, 06:00 PM   #2
First off is the outlet the end of the line or does it feed thru to other outlets?
Is the GFCi wired correctly?
Does the GFCI trip immediately or periodically?
Old 04-29-2012, 06:20 PM   #3
Good at being Evil
Shockdoc's Avatar
I had a problem likewise, I found another outside receptacle loadside on the other side of house completely saturated with water. I would check your line /load wiring first.
Old 04-29-2012, 06:22 PM   #4
Chief Electron Relocator
Is it on a MWBC? Is there load conductors hooked up?
Old 04-29-2012, 06:37 PM   #5
You sure your "line" side @ the new GFCI is not on the load side of another GFCI somewhere else?
Svtlightning207 is offline   Reply With Quote
Old 04-29-2012, 06:50 PM   #6
I know this is your dad's place and you want to help but I believe you are probably in over your abilities at this point. There are many possibilities and very little info to go on.
I will say this if the gfci trips right away then you probably hooked it up incorrectly. If it trips after time and there are loads down stream then it is likely something there is causing the issue.
Old 04-29-2012, 07:50 PM   #7
This amp goes to 11
If the outside outlet was just a standard outlet(no gfci) then I'll bet its already fed from a gfci in the house...my bet (cause I've seen it a bunch of times ) is kitchen or bathroom gfci.
TimChaput69 is offline   Reply With Quote
Old 04-29-2012, 07:51 PM   #8
Hire an electrician to come out and fix it for you.
Still sweeping it up: http://www.myfoxorlando.com/story/22...-still-unclear
Old 04-30-2012, 10:20 PM   #9
yalright thanks for the feedback so far... im almost positive its being fed from a gfci outlet from an upstairs bathroom and this outlet is at the end of the line
No outlet. erics37 Off Topic 12 01-27-2012 10:12 PM
Old GE gfi outlet BIGRED Vintage Electrical 13 11-08-2010 12:41 AM
220 outlet 1welder General Electrical Discussion 13 11-06-2010 11:27 PM
Old Outlet BIGRED Vintage Electrical 22 06-17-2010 02:06 AM
outlet katessa General Electrical Discussion 13 04-21-2008 08:08 PM
