05-03-2010, 07:25 PM
Government Contractor
Gutted house rewire, anything new since 2005?
Alright so here's the situation. My brother purchased a home at an auction for like 5k, it was so bad everything had to be gutted and redone (including trusts and roof). The only thing original on the house is the brick wall.
So he came to me to see about getting the electrical job and keeping it under budget. I haven't wired a house in about 4 years but i've wired around probably 50-100 residential houses while i was an electrician (as foreman) and probably 100 houses as a helper. Got a good offer on another job and left the electrical field.
We've got the permit pulled so there will be an inspection, i'm assuming we are still going off the 2008 NEC? Has the 2011 been released?
Are there any changes that anybody might be able to let me in on that i should know? Any major changes?
I'll probably pick up whichever version of the NEC i will need and run through it, just figured i would ask here first.
Thanks for the help guys!
TransCore Intelligent Transportation Systems
05-03-2010, 07:29 PM
ET Road Warrior
You first need to ask AHJ what code cycle your on... NEVER assume
The Associated Press wants to stop using the term "Illegal Aliens".. they say it is demeaning.. .. instead they want us to use Undocumented Democrats... Jay Leno..
05-03-2010, 07:30 PM
child please.....
Yeah a few....Arc fault breakers almost everywhere now....Leviton makes a "changes to the 2008" code pamphlet...you might want to start there...
The Following User Says Thank You to NolaTigaBait For This Useful Post:
05-03-2010, 07:45 PM
ET Road Warrior
Here is a link.....
http://smartgreenbuild.com/blog/download/338/
The Following 2 Users Say Thank You to B4T For This Useful Post:
05-03-2010, 07:56 PM
So just ask the inspector? I've never had to deal with any kind of "code cycle"? I worked for a small electrical company and we only had like 5 crews, i was just taught what was right and how to do it. What do you mean code cycle? Can i just call the county office?
Thanks!!
05-03-2010, 07:57 PM
child please.....
It makes a big difference...ask the inspector what cycle you are on.
05-04-2010, 05:04 AM
976-EVIL
How about just look on the permit when you pull it
05-04-2010, 06:01 AM
Yeah, that's what I usually do. The one I just got the other day (commercial) also had the ANSI 117.1-2003 spec on it that's going to be enforced as law. It has something to do with ADA requirements. I have to get a copy of it.
05-04-2010, 08:50 AM
child please.....
It doesn't say what cycle you are on here in Orleans or Jefferson Parish....You know we are 30 years behind the rest of the world here.
05-04-2010, 09:01 AM
ET Road Warrior
That doesn't work here either... we have (3) code cycles here in effect
05-04-2010, 03:52 PM
Okay so basically all they told us was "NEC 2008" ... i asked if there was anything else we needed to know for inspection and all he said was make sure it conforms to the 2008 NEC. So...i guess that's all i really need to do then. I'll look over the 2008 and that update spreadsheet posted on here.
Thanks for all your help guys!
Quick question, on the plans it has 4 GFI in the kitchen, can you no longer branch a duplex receptacle off the GFI? Before we would usually have two GFI in the kitchen and branch any other outlets off one of them.
Thanks!
05-04-2010, 03:57 PM
child please.....
Check out 210.52 for the required branch circits in the Kitchen.
05-04-2010, 04:40 PM
ET Road Warrior
Don't forget ALL receptacles, including GFI's, have to be (TR) tamper resistant.
05-04-2010, 05:07 PM
not a union thug
Nah, you're good.
05-04-2010, 09:59 PM
976-EVIL
That's ridiculous. You need that information. I've worked in dozens of counties in VA and they all list it. Some places inspect by USBC 06' some by NEC 05'. There are some differences, gas pipe bonding for one, is MUCH MORE expensive by the USBC.
05-04-2010, 10:15 PM
Better question is when did you do the last wiring you said you did. The last couple editions of the NEC each had changes that have an impact on how residential wiring is done.
Sounds to me like you better find out what you are going to need to do before you determine what the budget is. AFCI breakers and TR receptacles alone could change what you thought you should have for a budget.
05-04-2010, 10:38 PM
child please.....
Ridiculous?...Like I said, I live in Louisiana...What do you expect?...N o one wants to do their job , no one cares....the inspectors are a joke...Oh but you better have that green screw or green wire nuts on the grounds though
05-17-2010, 02:54 PM
#18
Yeah found that out quickly and had to return most material. Good thing my good friend works for an electrical supply house
Thanks for all the input guys!
